need help with blown mosfets..plz.... - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 18th June 2011, 10:39 PM   #1
Default need help with blown mosfets..plz....
hi everyone.... i would really appreciate any help. my amp shorted cuz a little water went it it. i saw blown mosfets and resistors. i saw a few videos and thought it would be a piece of cake so, i replaced all six irfz44n mosfets and resistors. now when i hook it up the amp turns green and the power wires get hot like crazy and start to smoke and the mosfets get really hot too but the audio comes on and after about 15 seconds the amp goes into protect . is the amp still shorted??? plz guide me to test the amp for shorts as im relatively new to electronics. thanx in advance
Old 18th June 2011, 11:29 PM   #2
also the insulator of audio side transistors lost and they are in direct contact with body.. can this cause the short??
Old 18th June 2011, 11:36 PM   #3
nigelwright7557's Avatar
Could be you have blown the driver components too.
Check the driver transistors for shorts.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 1st July 2011, 07:14 AM   #4
plz everyone i need valuable advice..... 58 views and only one suggestion?? plz reply
Old 1st July 2011, 07:47 AM   #5
Radugazon's Avatar
No panic...you have to check every stage methodically, first the power supply : deconnect it from the board and check if it's symmetric. Then, if you don't found an evident short (as you said, if the micas are gone !!!), try the amp but with only one channel supplied at once. Cut the tracks if necessary. Like this you will see better what's wrong.
plz help!! what is this?? usmcgrunt0331 Parts 15 18th September 2010 06:28 AM
Blown mosfets agithegreat Car Audio 59 3rd August 2009 03:42 PM
n/p Mosfets vs depletion mod mosfets marcello7x Car Audio 6 4th October 2006 05:01 AM
JBL S120PII: Blown Mosfets Gamer Class D 0 5th December 2005 07:55 AM
Reasons for blown MOSFETs? JoeBob Solid State 8 16th March 2003 10:07 PM
Copyright 1999-2017 diyAudio
