Low Noise Linear regulator power supply
Hello
I am looking for 5V 0.4A Linear regulator for car enviorment the regulator should accept 13-14 (varliable -car electric system) and provide clean 5V with very low noise/ripple the power supply is for USB to S/PDIF converter for more information please look at the following link, which describe power supply for home similar to what I need in car: USB Low Noise Power supply, low noise power supply, audiophile power supply, usb dac power supply Thanks |
Are you planning to build it or buy it?
I preffer to buy one, becuase I don't have experience of building electronic circuits
but I none exsist for my specific requirments I will build or pay some professional to build for me |
No ripple to worry about, clean depends on installation as much as anything, likewise noise - it shouldn't be a problem unless the vehicle has it's own issues or the driver likes to leave the blinker on. :)
I Googled "car dc converter -inverter +regulated". I don't know where you are, but the Coby CA709 IC Regulated 800mA Universal DC Car Converter is available from the world's largest retailer. |
this is simple switching power supply and not linear power supply
it probably have ripple and noise I need something equal to the supply I post in the link above that fit to car elecrical system Thanks |
DC-DC converter = voltage regulator.
anyone can recommend of device meet this specification?
I've read about that AQVOX adapter before and haven't seen anything like it for cars.
But... you could use a 12vdc to 120vac auto inverter Walmart.com: DP Audio Video, Car Power Inverter: Auto Electronics then plug the AQVOX into that to take it back down to 5vdc. :D The AQVOX seems to be well filtered so it should get rid of any noise from the inverter. Like Andrew says technically all you need is a LM7805 regulator IC with a filter circuit in front of it. But if you are not into building circuits then the above would do the job. |
can you recommend me of such regulator?
| All times are GMT. The time now is 04:44 PM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
