Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th June 2011, 07:31 AM   #1
Default LM1117 in DAC power supply
Hi:
I want to step down linear regulated 5v to linear regulated 3.3 volt for DAC. Current draw will be 200mA but I need really clean supply.
Using Nationals’ schematic, I plan to use LM1117-3.3, a 10uf tantalum at the input, a 10uf tantalum at the ouput and a 0.1uf ceramic bypass at the output. Will it be enough or any suggestions about parts?
Old 4th June 2011, 09:07 AM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
as they say, you should use just that
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 6th June 2011, 07:45 AM   #3
Pryanick's Avatar
Send a message via ICQ to Pryanick
Default DAC PSU Filtering
You can see LM1117 in my DAC schematic.
I use it for 5 years.
LM1117 is good for this.
Old 7th June 2011, 03:50 PM   #4
Default type of capacitors and inductor
Thanks Pryanick!
You are using a 470mh inductor after LM117-3.3 for CS8416 VA supply but just capacitors after LM1117-5 for CS4391A VA.
What difference it makes? Also can you share the type of capacitors and inductor you used for LM117-3.3?
Old 10th June 2011, 05:12 AM   #5
Pryanick's Avatar
2 new2hifi
Hi
1. 470mh inductor gives us some power source decoupling VD from VA cuz i use same volts and same voltage stabilizer for them. You can remove inductor and make separate power source unit with LM1117-3.3v and two caps for CS8416 Analog part. Hope it will be a little bit better then i did
2. Capacitors for CS8416 VA&VD and for CS4391A VA&VL are tantalum.
Huge caps like 2200x16v x25v are ordinary caps.
More photoes here
Old 16th June 2011, 02:53 PM   #6
[QUOTE=Pryanick;2600545]2 new2hifi
.....Hope it will be a little bit better then i did .......
Thanks for help Pryanick! I am just a beginner thus no chance of exceeding you.
Old DAC and power supply schematics Sandor Digital Line Level 3 15th October 2010 10:31 PM
Dac Power Supply kkchunghk Power Supplies 3 13th September 2008 03:19 PM
DAC Battery power supply dzkh63 Digital Source 2 25th April 2007 01:40 PM
DAC Power supply elec-tron2 Digital Source 1 7th April 2007 11:57 PM
non-os DAC power supply.. reMC Power Supplies 1 11th June 2005 12:54 PM
Page generated in 0.08545 seconds (74.18% PHP - 25.82% MySQL) with 11 queries
