Should I twist the positive, negative and ground wires together in the run from the PSU board to amp board?
I am thinking of eg twisted pair Ethernet cable: twisting the wires reduces EMI broadcast from a signal/return pair. Does this matter for an approx six inch power cable run (which is rather high current) - or am I being too paranoid? Thanks in advance! |
#2 |
Banned
It wont hurt and will help to keep them out of the way of signal cables.
#3 |
I have come to learn that all flow and return pairs must be of minimum loop area.
Twisted triplet for the PSU supply is my way only method.
regards Andrew T. |
#4 |
The ideal is to use a shielded case and keep them away from a toroidal transformer. If you do that, there is no need to twist them. Twisted pair ethernet cable uses the twists because it is a high frequency signal while you (should be wanting) have as low a frequency ripple on your power rails as possible. Granted it is also for rejection of noise pickup but that is why you'd use a shielded case.
If you want to twist them, run two ground lines instead of one and twist positive rail with one ground and negative rail with the other, you don't want all 3 twisted together so that rail noise from one rail effects the other rail, in a shielded enclosure that should technically (although I'm not suggesting you can necessarily hear it audibly) be worse than not twisting them at all. |
#5 |
Banned
Ensure reliable connect Large enough wires
| Using PC PSU for Sure 4x100 amp board | RhinoDude | Power Supplies | 2 | 14th September 2010 05:11 PM |
| Power Amp PSU Board (for e.g. LYNX Amp) | Jan Dupont | Group Buys | 462 | 4th September 2009 12:31 PM |
| MISSION PCMII analogue stage board connect? | Chayaphat | Digital Source | 0 | 8th November 2005 11:13 AM |
| Page generated in 0.07516 seconds (74.23% PHP - 25.77% MySQL) with 10 queries |
