Hi i have two transfomers 4A 12-0-12.I want to build a power supply using the two transfomers so i will get 12v 8A if possible?.Any help would be appreciated.Schematics to
#2 |
You will get 2x12V 8A if the transformers are identical and you parallel them.
#3 |
do you need 12Vac @ 8Aac
or do you need 12Vdc @ 8Adc?
regards Andrew T. |
#4 |
The transfomers are indentical
i need 12vdc @8A |
#5 |
for 12Vdc @ 8Adc you need a 9Vac 150VA to 300VA transformer
regards Andrew T. |
#6 |
I dont have any other transfomer,wanted to use what i have.
What if i put the two in parallel just like "kubeek" said but i only used the center taps and 12v and leave the other 12v out are the amps going to increase? |
#7 |
am not sure for the amps for the bridge
#8 |
Parallel the transformers normally and use a full-wave rectifier with the center tap as ground and a choke filter.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#9 |
no matter how you try to connect two 12-0-12Vac, 4Aac, you cannot get 9-0-9Vac, 16Aac
regards Andrew T. |
#10 |
| Chip amp power supply- a beginners guide | Nuuk | Chip Amps | 702 | 20th May 2012 05:48 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.08662 seconds (76.50% PHP - 23.50% MySQL) with 11 queries |
