Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th May 2011, 12:30 AM   #1
dobias is offline dobias  United States
Default parallel tube rectifier filaments
As a noob, I gather that independent tube heater power supplies are beneficial, but does that include parallel tube rectifiers filament supplies?
Would a single filament transformer for both tubes be just as good?
Old 27th May 2011, 12:36 AM   #2
tomchr is offline tomchr  United States
tomchr's Avatar
Most tube rectifiers connect the filament to the cathode, hence, the two rectifiers would need to be tied together at their cathodes for you to be able to use one transformer to power both tubes. If that is the case, then I see no benefit of using two separate transformers or windings to power the tubes. As long as a single winding/transformer can supply the needed current.
~Tom
Old 27th May 2011, 01:16 PM   #3
Tom,
Thank you very much for the clairification.
I've just now used the 10vac tap & wired the two tubes in series with the center tap back to the B+. Now I need to reduce the actual 11vac (no load) down to 10vac. The Triad transformer is 4A so it shouldn't read high, should it?
Old 27th May 2011, 01:18 PM   #4
Tom,
PS: I'm using 5R4GYA tubes.
Frank
converting tube rectifier to solid state rectifier. tubo Tubes / Valves 26 24th December 2009 12:12 AM
Switching power supply for tube filaments possible??? noyan Tubes / Valves 12 17th September 2008 01:32 AM
Low vs High aka Series vs Parallel Filaments ak_47_boy Tubes / Valves 10 22nd April 2007 06:05 PM
Tube filaments in series? Klimon Tubes / Valves 7 7th April 2007 09:16 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Page generated in 0.06203 seconds (79.39% PHP - 20.61% MySQL) with 10 queries
