Go Back   Home > Forums > Amplifiers > Power Supplies
Old 24th May 2011, 06:38 PM   #1
Default Diode regulator VS IC regulator.
As the title suggests, I am interested in the differences between these two types of regulators.
I can see advantages to using a diode based regulator if high current is needed also if you don't have the 3v overhead an IC regulator would require. One disadvantage would be possible temp stability issues.
IC regulators can easily be used with a high power transistor if the extra current is required.
Aside from those things, I don't really have a grasp on the regulation properties of the two types.
There must be some inherent advantage with the IC regulators, because everyone seems to be using them.
Old 24th May 2011, 07:07 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
Diode regulator, never heard of. Can you explain?
/Per-Anders (my first name) or P-A as my friends call me
Old 25th May 2011, 09:03 AM   #3
mastodon's Avatar
You mean a simple shunt regulator using zeners?
Anyway, concerning the voltage drop: note that you always need some drop just to maintain regulation.
Old 25th May 2011, 09:56 AM   #4
DF96 is offline DF96  England
A zener diode is a shunt regulator. It will need to consume a certain minimum current in order to regulate. There must be a resistor in series with the supply so that the current can drop the voltage. Shunt regulators waste power.
Most ICs are series regulators. They still waste power, but less than a shunt regulator. They are more complex, and may have a non-trivial output impedance which may or may not cause stability problems. They may be temperature-compensated so more stable than a simple shunt regulator.
Old 27th May 2011, 07:27 PM   #5
'non trivial output impedance' This is true. But the effective output impedance for simple shunt regulators, like zeners or diodes, is pretty horrific - at least two orders of magnitude worse than even the most basic simple 3-pin reg (in the audio band)
Old 31st May 2011, 03:38 AM   #6
twest820's Avatar
3V implies a standard linear regulator with moderate ripple and zener regulation implies a low current load, in which case there are any number of low current LDOs that would work. Micrel's uCap line is a good starting point; relatively low cost, simple stablity requirements, good range of input and output voltages, and compact on the board.
Regulator IC application lauret Power Supplies 1 25th October 2008 12:52 PM
IC Power regulator sandmaniac Solid State 2 16th July 2007 10:03 PM
Need a CRD E-102 (current regulator diode) ostie01 Parts 2 10th August 2006 09:13 PM
regulator protection diode starushz Power Supplies 12 26th January 2006 02:46 PM
Best IC voltage regulator.... DanK Solid State 22 11th November 2001 06:33 PM
Page generated in 0.08537 seconds (72.45% PHP - 27.55% MySQL) with 10 queries
