Go Back   Home > Forums > Amplifiers > Power Supplies
Old 24th May 2011, 05:52 PM   #1
Default Help needed with complimentary pair.
Can anybody help with this design. I have a P-channel Mosfet connected with N-channel in a complimentary configuration. It is across a split supply, where P-channel source is connected +30V and the N-channel source is connected to -30V. The drains are connected together and are linked to one end of an inductor.
I want to connect a load from the inductor/capacitor output to ground. I need an output of 15V and upto 15A out. At the moment I am getting my output voltage of 15V, but when i load the output, my +30V starts to increase and my output starts to drop.
Hope you can help....Thank You.
Old 25th May 2011, 07:50 AM   #2
Elvee is offline Elvee  Belgium
Looks like your lower transistor is acting as a boost converter, with the the body diode of the upper transistor functionning as a rectifier.
What's the purpose of your circuit?
Old 25th May 2011, 09:10 AM   #3
The circuit is going to be used to give 15V output which will be switched every ten minutes to give +15V then -15V and so on...with variable currents upto 15A.
Old 25th May 2011, 11:34 AM   #4
I think the control strategy of your transistors is wrong.
The common point to the inductor should never be left high-impedance.
You must operate your half-bridge like a class D amplifier.
Complimentary-symmetry SUSY? vossie Pass Labs 19 16th February 2004 06:01 AM
complimentary pair Randy Knutson Parts 5 31st March 2003 11:55 PM
Page generated in 0.07164 seconds (71.82% PHP - 28.18% MySQL) with 10 queries
