Go Back   Home > Forums > Amplifiers > Power Supplies
Old 22nd May 2011, 03:43 PM   #1
digits's Avatar
Question 75VA EI or 80VA toroid.
Hi guys, I'm trying to choose a transformer for my new baby amp, it only needs to provide a max of 40W per channel (there will be one supply per channel). Which would you choose? the 75V EI weighing 2.2kg or the 80VA todoid weighing 0.95kg. There is less than a dollar diffirence between the two due to diffirent suppliers, one being a retail outlet of a manufacturer. They take up about the same footprint, torroid is 38mm x 96mm, EI is 100x95 and 90mm high, which is still cool as I am useing 4inch sinks.
Old 22nd May 2011, 04:51 PM   #2
There is a lot more to consider. What is the "regulation" of both transformers? Is the EI one winding over the other or a split bobbin with side by side windings?
Old 22nd May 2011, 04:53 PM   #3
I agree with Simon, check the regulation.
regards Andrew T.
Old 23rd May 2011, 10:26 PM   #4
Keep in mind also that usually toroids have more parasitic capacitance between the coils: more high frequency noise is coming from the line.
EI generally leaks more field (not good if you don't want hum in the nearby circuits).
If the EI is a "split bobbin" (which gives you extra decoupling and safety) I would go with it; if the trafo should go near low signal circuits, I would use the toroid.
Old 23rd May 2011, 10:51 PM   #5
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
i am for the EI......
FS: 80VA 2x18V Encapsulated Toroidal transformer maxw Swap Meet 1 21st May 2011 05:09 PM
WTB 2X70V or 140-0V 50-80VA power transformer with 120V primary gaborbela Swap Meet 0 28th March 2010 03:49 PM
WTB: 120VAC->15VAC 80VA transformer 454Casull Swap Meet 0 25th October 2008 03:01 AM
Trade a 40V 400VA Toroid for 20V 300VA Toroid john65b Swap Meet 7 10th October 2006 03:49 AM
~80VA 28VCT transformers Tweeker Swap Meet 9 14th November 2005 08:45 PM
Page generated in 0.08869 seconds (72.76% PHP - 27.24% MySQL) with 10 queries
