Need a 12.6 VDC power supply schematic - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 21st May 2011, 02:32 PM   #1
Default Need a 12.6 VDC power supply schematic
Hello everyone. I recently finished my hybrid 12AU7/IRF510 headphone amp, and it sounds wonderful The problem is, there's a bit of hum every once in a while, and I think it's the power supply that's the problem. Here's a schematic for it:
Now I've tried building that schematic 2 times, but it outputs about 15 VDC I'm looking for a regulator schematic that inputs about 15-20 VDC and outputs 12.6 VDC. If anyone has any suggestions I would be really thankful
Old 21st May 2011, 02:40 PM   #2
TG is offline TG  Ukraine
Send a message via ICQ to TG
Changing RR1 from 120 to 270 Ohm will be quite enough.
Old 21st May 2011, 02:50 PM   #3
Thanks, I'll do that and report back here
Old 28th May 2011, 05:05 PM   #4
I changed RR1 but it still outputs about 15 VDC. I don't think it's the LM317, since I tried 3 different ones. Can anyone give me another schematic for a 12.6 VDC regulator ?
Old 28th May 2011, 05:17 PM   #5
Can anyone please help me ? I need this quite soon...
Old 28th May 2011, 05:34 PM   #6
What voltage is at the LM317's IN terminal?
Old 28th May 2011, 06:00 PM   #7
tomchr is offline tomchr  Canada
tomchr's Avatar
The schematic is fine. The issue is with the resistor values. Try these values:
RR1 = 220 ohm
RR2 = 1500 ohm
RR3 (pot) = 1000 ohm
The output voltage is Vout = 1.25*(1+(RR2+RR3)/RR1) in your case. Hence, above values should yield an adjustment range of 9.8 ~ 15.5 V.
~Tom
Old 28th May 2011, 06:11 PM   #8
Banned
I think your Vin is too low, the LM317 needs about 3V to operate. As an experiment try increasing Vin, try about 18VDC that should prove the point.
Old 28th May 2011, 06:27 PM   #9
Initial resistor values (with RR1 = 270 Ohm) are fine too.
I have a suspicion that DR3 and/or DR2 are mistakenly reversed.
With too low Vin LM317 should output about Vin-1.2..2V depending on load, so I believe this is not the case.
Old 28th May 2011, 08:35 PM   #10
It seems the trim potentiometer wasn't properly working. Well, actually, not one, but THREE of them ! I am that unlucky. I bought a proper trim potentiometer so now it works.
a free but not working Stabylex 12 VDC power supply to any one giggleherz Power Supplies 3 18th April 2010 05:14 PM
12 vdc to 18 vdc isolated P-P jamesrnz Power Supplies 89 4th February 2009 03:36 PM
schematic for 12.6 VDC heaters cbutterworth Tubes / Valves 7 5th March 2007 07:09 PM
48 VDC Power Supply construction ?s PaulHilgeman Parts 2 15th January 2003 12:14 PM
Using fuses on VDC Power Supply Rail? Lucas_G Pass Labs 4 22nd December 2002 09:37 PM
Copyright 1999-2017 diyAudio
