Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th May 2011, 09:38 PM   #1
BrianVG is offline BrianVG  Belgium
Default Line voltage selector Revox B750 MK II blew up
Hi all,
I thinks this fits in the power supply forum.
I was listening to my Revox B750 when I suddenly saw smoke, lots of smoke!
I instantly turned the amp off and pulled the plug out. We were afraid that the whole thing was on fire because of the smoke (the room was really full of it).
The smell of the smoke was really bad, my first tought was that a big cap blew.
After opening some windows, I opened the amp.
I could see the problem in an instant.
It has something to do with the voltage line selector.
Right now the selector is set to 240VAC (Belgium => 240VAC, 50Hz)
As you can see this 'thing' has caugt fire, the only thing I read on it was
"250V, fo 9MHz"
What is this component?
Also: the fuse is not blown and the music kept playing when smoke was coming out.
FET fanatic
Old 20th May 2011, 09:43 PM   #2
FET fanatic
Old 20th May 2011, 10:21 PM   #3
Looks like a noise suppression capacitor, X or Y type.
The dielectric got compromised, just snip the leads and remove it.
If you really want, replace it with the proper type, around 100nF (try to see the rating of the original one). Type X if it does not go to ground (most likely). Type Y if it does.
Old 20th May 2011, 10:26 PM   #4
Old 20th May 2011, 10:33 PM   #5
Will a WIMA MKP capacitor do the job?
I've used them in some amps, they are alot smaller than the cap I blew.
I've got my hands on the schematic of this amp. Maybe this could say what value it was.
FET fanatic
Old 20th May 2011, 10:41 PM   #6
100nF indeed, thanks discrete!
FET fanatic
Old 21st May 2011, 12:25 AM   #7
NO!
Has to be an X-rated type (not what you think...).
Try to get X1, if not X2 is ok.
http://www.vishay.com/docs/28117/mkp3361.pdf
You can also safely leave it out, at the risk of picking up some electrical noise through the mains feed.
Old 21st May 2011, 08:15 AM   #8
I'm not familiar with X or Y type capacitors.
I went on a searchs in my recycled component. And I found one it has X2 printed on it, the value is 330nF
FET fanatic
Old 4th August 2011, 04:03 PM   #9
I had the same problem a few days ago. i must need to change component or i can use this amp without ? voltage must be set to 240 VAC?
REVOX B750 INTEGRATED AMPLIFIER SCHEMATICS VRK Solid State 2 17th November 2010 05:58 PM
Classic Aragon (2004, 2004 MK II, 4004, 4004 MK II ) problems, experience and repairs MagicMarksy Solid State 1 22nd May 2010 03:36 PM
NAD 2200 help with line voltage selector mrzoo Solid State 3 24th July 2007 04:43 PM
Gumby MK II !! Andy G Multi-Way 1 19th July 2005 03:39 AM
Page generated in 0.09902 seconds (77.03% PHP - 22.97% MySQL) with 10 queries
