Hi all. I just want to make sure I have my calculations set. I'm looking to buy one of These on ebay and I want to make sure I have my power supply all set up correctly. I'm looking to buy the 500W 40V toroidal transformer from PE (located here) which seems to satisfy the requirements for this amp (look about halfway down the ebay page where it says "Recommended AC 400W Dual 40V AC power transformer above."). All would be well, except that I messaged the seller and he said that I would need a power supply as well. To my knowledge, this transformer will take 115VAC from the wall and I won't need a separate PSU. Is this correct? I'm confused as to why he told me to get a PSU as well when this will easily just plug into the wall. Could anyone please clarify? Thanks!
#2 |
Yes, you will need a separate PSU as the transformer outputs AC current which must be rectified to DC before being fed to the amplifier module. Some modules have a power supply mounted on-board to change AC into DC however, this one doesn't and you will need a power supply board with rectifier and filter capacitors.
Something like this from the same seller would do and would be up to the voltage rating of your power transformer (it uses 80V capacitors whilst other kits use 50V ones-cutting it a bit fine IMO). The primary side of the transformer is connected as usual with just the live and neutral along with a switch and fuse on the live line. The secondary (where the lower voltages are produced) will connect to the power supply board which in turn will turn your incoming AC to DC and filter it (reducing the ripple). The output of the power supply board will then go to the amplifier module. |
#3 |
I like the look of that Capacitor board from ebay, but I usually have some lower capacity caps on there as well. It may not be necessary and is probably overkill but that is how I usually put power filters together.
#4 |
a single secondary transformer with 40Vac will give you a single polarity ~60Vdc supply. If the amplifier needs a dual polarity supply then the transformer must have either: dual 40+40Vac secondaries or centre tapped 80Vac secondary.
regards Andrew T. |
| SMPS Transformer Primary Turns Calculations | AutoClassA | Power Supplies | 6 | 14th January 2012 07:00 PM |
| Calculations for MC Transformer | Binaural | Analogue Source | 2 | 22nd April 2009 07:14 AM |
| Equations,Calculations & Theory of FERRITE TRANSFORMER design | dhanukak | Power Supplies | 4 | 17th September 2007 02:41 AM |
| Calculations for new Power transformer | kskr | Tubes / Valves | 3 | 3rd May 2006 09:29 AM |
| Page generated in 0.07649 seconds (75.69% PHP - 24.31% MySQL) with 10 queries |
