Improve grounding with a box?
The Silence of Grounding | Stereophile.com No white paper, no description of what's inside? |
#2 |
SNAKE OIL!
#3 |
I note that it was designed by a salesman. The blurb pushes all the right buttons: a little bit of 'science', and some exotic materials from the Third World. The high price means that nobody will buy it and then tell their friends that it was a mistake; they will genuinely believe that it makes an improvement, because to believe otherwise would imply that they had more money than sense.
#4 |
9 n's pure oxygen free harmonically aligned snake oil no less
Repairs and mods to Real Hi-Fi, guitar amps and P.A. in North East England. http://www.arklesselectronics.com |
#5 |
I usually do it with kryptonite powder painting, if not available then Uranium 235 isotope gel can do the job as well.
#6 |
I have just burned my copy of "Electromagnetic Compatability Engineering" as it is obviously teaching me the wrong way to do things!
Having a quick look at their site, it is another product that help electrons flow! as the approx speed of electrons is 84mm/hour will this do any good. Last edited by marce; 18th May 2011 at 11:36 AM. |
#7 |
I have bought 2 of these boxes, 1 to put my phonoPS in and the other for the phono itself. Very high quality sound, worth the money.![]() But serious, we need pictures from the inside & scematics before making conclusions. Last edited by acidbrain; 18th May 2011 at 11:41 AM. |
#8 |
With any device discussion is helped with a schematic. In this case I doubt one will be released. So discussion could go on and on. But it is likely Inductance Capacitance are enjoying each others company.
Every success to its designer and a general reminder to pay attention to grounding in any serious audio layout . Remember though that any grounding is only as good as the rod in the ground itself, and the deeper it goes to a maximum of about 25 metres is in most cases -well worth the investment, particularly in lightning prone areas . Cheers / Chris |
#9 |
The rod in the ground is for protective earth, to correctly ground systems you dont need a rod in the ground. In fact if you avoid the mains ground (PE) connection totaly you will have less noise to worry about, a lot less.
#10 |
I'm sticking my own rod in the ground, humfree naturally.
| Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... | EchoWars | Solid State | 37 | 3rd August 2008 08:50 AM |
| Help to improve | Leolabs | Solid State | 6 | 26th December 2006 05:34 AM |
| How to improve this amp | thermonuclear | Chip Amps | 2 | 13th September 2005 06:38 AM |
| LM3875 kit grounding, optimal grounding for separate amps and psu? | findog | Chip Amps | 9 | 16th May 2005 09:27 PM |
| Page generated in 0.10038 seconds (76.47% PHP - 23.53% MySQL) with 11 queries |
