Go Back   Home > Forums > Amplifiers > Power Supplies
Old 16th May 2011, 01:24 PM   #1
maurycy is offline maurycy  United States
Default Question about 110V to 220V converter
Is there a way to tell what's the idle current that the 110V to 220V converter will draw in standby mode? Let's say that the converter is 1600W.
I am asking because I would like to see if I can leave it on 24/7 or it would be more beneficial to convert all my stereo gear to 220V once I move back to Europe.
Thanks.
Old 16th May 2011, 01:38 PM   #2
Banned
Simple way is, measure it.
A good transformer will draw almost ZERO current when not under load. This is often not the case though and any transformer will draw a minimum current.
It'll be far more expensive to convert all your gear because most of the transformers may be custom made and difficult / expensive to obtain in their 240V versions. I good 1600VA transformer will be the cheapest option in the long run.
If necessary buy a STANDBY KILLER, these are designed to TURN OFF equipment that has been left dormant or in STANDBY.
Old 16th May 2011, 01:41 PM   #3
Thanks for the reply. Unfortunately, I do not have the transformer so I can't take any measurements. As to the gear, I would just sell off my vintage 110V stereos and buy multi-voltage replacements.
Using 220V transformer on 110V ZenCow Power Supplies 36 8th January 2011 12:58 PM
Micronta bench power supply & 110V-220V converter transformer USA boywonder Swap Meet 0 3rd October 2010 09:57 PM
another 220v to 110v question amoncarter Parts 7 11th July 2010 09:11 PM
110v or 220v, how can you tell? fjmart134 Tubes / Valves 2 8th June 2009 10:18 PM
Simple question regarding converting chipamp from 110V to 220V maurycy Chip Amps 16 8th December 2008 11:58 PM
Page generated in 0.06762 seconds (68.66% PHP - 31.34% MySQL) with 10 queries
