Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th May 2011, 11:47 AM   #1
gearheadgene's Avatar
Default inrush bypass using smps output
Does it make sense to use a secondary winding from an SMPS to control the bypass device of the inrush circuitry? For example, if the design has a bias winding to supply the PWM chip, why not use it to also drive a bypass relay or triac?
I've been looking through a lot of the inrush posts but have not seen this method (maybe I missed it).
gene
Old 15th May 2011, 04:09 PM   #2
darkfenriz's Avatar
Now examine what will happen if the output is short.
Old 15th May 2011, 04:12 PM   #3
kubeek is offline kubeek  Czech Republic
Send a message via ICQ to kubeek
Or just under full load.
Old 16th May 2011, 01:34 AM   #4
OKay - I see what you are getting at, but . . .
Output is short, PWM goes into cycle-by-cycle limiting, bias-winding never reaches designed level, so inrush circuit stays active. Depending on PWM design, the system will be calling for maximum current, and will stay that way - so the inrush limter takes a beating. But what if the PWM goes into hiccup mode - maybe the power consumed by the inrush limiter is ok.
On the other hand - maybe it's better to keep the inrush limiter active just long enough to fully charge the input capacitors - keeping the PWM inactive until that is done
Old 17th May 2011, 07:57 PM   #5
darkfenriz's Avatar
Inrush limiting resistors are never rated for any steady state. There may be several times more power dissipated in them for a short time, so for me it is vital to ensure they are bypassed after calculted time. Bypassing them too early risks some inrush, which may or may not be a problem, keeping the bypass open for too long, while the load wants to consume the power is a direct fire risk.
That's why I think your proposed solution won't get my favourite.
Old 21st May 2011, 06:25 PM   #6
Fire . . . bad
Old 11th June 2011, 10:48 AM   #7
So what about NTC, with relay bypass activated after SMPS comes alive? NTC do not have the fire hazard problem. Seems pretty like a simple solution.
Old 11th June 2011, 01:00 PM   #8
Do you even need to bypass the NTC? I would say it should "bypass" itself when it gets hot, shouldn´t it?
Old 11th June 2011, 01:00 PM   #9
there is no reason at all that you cannot do as you said in your first post.
..i.e. using a turn on the trafo to give you power to switch your bypass FET.
You are right.......short circuti on output will take the pwm controller into hiccup mode, so no worries for your inrush resistor overheating.
Old 28th June 2011, 10:59 AM   #10
Here's something I've worked on - what do you all think? The circuit has 3 section:
1) top portion is the AC to DC section
2) middle left is a 10 Volt regulator
3) center bottom is a timer
4) bottom right UVLO
R1 is either NTC or power resistor to control inrush. Not shown yet is a bypass arrangement - either relay or triac, for example.
Okay - operation goes something like this:
AC power is applied. At t=0, J1 is conducting, which holds UVLO low.
That keeps my PWM in reset. As the DC rises (Vout), the 10 volt regulator
fires. That starts up the timer circuit. R7 and C4 set the ramp rate. This thing
is very low current operation. When Vtest reaches 2.5Vdc, the TL431 conducts.
This brings the gate of M2 low enough to turn it on, and now the gate of J1 goes
high, turning J1 off. Now the UVLO circuit works normally, and the PWM is out
of reset.
I've got the time constant set to around 1.5 seconds. It can be any time - very easy to adjust.
Stuff not shown:
1) PWM bias supply. It has to be greater than 10V, and connects to V10 through a diode. So when it becomes active, it turns off Q1 and Q2, and now supplies the timer circuit and keeps things status-quo.
2) Bypass for NTC. I think it would run from the V10 supply, use a transistor to turn it on, and use the signal at gate of J1 to control it.
Stuff that I don't like:
1) Q2 consumes a lot of power when it's on - like 40W in this example. That assumes a load of 100 mA. That's probably way overkill - also the time it is active is only 1.5 seconds. Once the PWM is running, there is no power consumption. In any case, I plan to use a package that can handle this.
2) R4 also is a power hog - just not quite so bad. Maybe .75 Watts. In this diagram, it will always be active even after PWM is running. Maybe should add something to turn it off.
Hypex SMPS DC Error detection and DC blocking cap bypass MaartenJ Class D 4 7th January 2011 10:58 AM
bypass output capacitor wicked1 Pass Labs 8 22nd August 2009 09:49 PM
Cathode Bypass in a PP Output Stage CLS Tubes / Valves 8 15th July 2008 05:32 AM
AD825 output stage:What bypass caps? filholder Digital Source 3 16th April 2005 06:15 PM
cathode bypass in PP output stage? RichJones Tubes / Valves 23 31st October 2003 09:30 PM
Page generated in 0.11618 seconds (79.54% PHP - 20.46% MySQL) with 11 queries
