LM317 experiments and measurements - Page 11 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 26th December 2011, 10:36 PM   #101
gpapag is online now gpapag  Greece
gpapag's Avatar
How can my Body be 1/2 V different in potential to the air around it
Donít try to build a case out of this. Just consider the difference in potential between your and your wifeís body. Some hundred volts or so?
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 27th December 2011, 09:46 AM   #102
RF attenuate the mains input.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th December 2011, 10:05 AM   #103
just another
wintermute's Avatar
George, way too high a potential difference at times but some contact usually sorts that out
Thanks Andrew I went and bought an IEC socket with EMI filter in it today. I'm just trying to work out the layout of the prototype chassis. They only had the one type, a 6A one. After googling it and finding the datasheet I should have tried to get a 1A one. The lower power ones attenuation is a lot better. Oh well I need one on my mosfet amp so may find another and replace when I do the final chassis and put this one into the mosfet amp.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 27th December 2011, 11:44 AM   #104
I bought a few batches on Ebay.
I have a stock of 1A, 3A, 6A, switchable, fused, etc.
I refuse to pay for one at a time, when I know what I am like.
regards Andrew T.
Old 27th December 2011, 01:05 PM   #105
Here is my Power Supply Adjuster Experment 3 amps transformer but i used LM317 instead of LM350 0-30 volts but exceeded in 37.5volts
Old 27th December 2011, 01:45 PM   #106
Attach your documents.
regards Andrew T.
Old 27th December 2011, 02:56 PM   #107
i don't know why my pics was remove.. but i attached my pics here,,, i think you going to download it... just like what i've post a while ago... i used LM317 instead of LM350 because LM350 is designed for 3 amps. while the LM317 is Designed by 1 amp... so is doubled it in order to avoid Over Heated..
Old 27th December 2011, 08:29 PM   #108
just another
wintermute's Avatar
good reuse of a pc power-supply case
Tony.
Some of my photos
Old 27th December 2011, 11:47 PM   #109
Indeed.
Also Schaffner that I typically use have product lines with different attenuation ratings (normal, good, high, very high or something along those lines) and other features (e.g. with earth choke or w/o) which differentiate IECs with the same current ratings.
So, not even all Schaffner filtered 1A IECs are created equal.
Old 28th December 2011, 02:38 AM   #110
just another
wintermute's Avatar
Thanks, I found a source of Schaffner here in aus at reasonable prices I shouldn't have been so hasty to go out and get one.... the datasheet doesn't seem to say what the difference is between the one with a bleed resistor and one with out (performance wise). The fn9244-1-06 seems to fit the bill nicely. I'm guessing that the bleed resistor may improve rejection at certain frequencies. http://www.schaffner.com/components/...%20e%20103.pdf
Tony.
Some of my photos
Screen drive and other P-P experiments Tubelab_com Tubes / Valves 23 6th July 2010 06:08 PM
Initial Experiments for Fun stuphi Multi-Way 17 4th June 2009 05:19 PM
My first horn experiments till Multi-Way 110 31st May 2004 02:55 PM
x-over experiments, diff. orders etc. SimontY Multi-Way 25 19th February 2004 11:19 PM
Copyright ©1999-2017 diyAudio
