I have a rather bulky/ tall ei core transformer for my dac. So instead of buying a 4U high chassis, i was thinking about laying the transformer flat (of course properly mounted).
Can i do this and what will it do with any RF to surrounding components? Thanks |
#2 |
Nobody? Or stupid question?
#3 |
You are unlikely to get RF from a transformer, unless your rectifiers generate it. You may get hum or buzz. Magnetic flux will mainly follow the core, but some will leak out. Wires/components which are parallel to the windings are most likely to have a voltage induced in them. For PSU components, which are the only ones which should be near the transformer anyway, induction should not be an issue as direct currents through them are likely to be greater. Distance is more important than orientation.
#4 |
Yes, you can do it if properly mounted.
| what are the advantages of double core output transformers vs EI ? | bembel | Tubes / Valves | 12 | 2nd November 2006 02:24 AM |
| best material for mounting tubes sideways | karma | Tubes / Valves | 15 | 21st August 2005 06:16 PM |
| Any website reference for diy choke ,siliver R-core, C-core, EI and power transformer | bmpa | Parts | 2 | 22nd April 2004 04:15 AM |
| EI core transformer for step-up PSU | Solid Snake | Solid State | 7 | 9th December 2003 04:29 PM |
| Sourcing EI core materials | Chong-Han Gan | Everything Else | 1 | 21st December 2001 01:35 AM |
| Page generated in 0.05846 seconds (79.63% PHP - 20.37% MySQL) with 10 queries |
