I am putting together my own PSU based around a antec AN-5458 500VA torroid, Antek - AN-5458 However i am also preparing for a move from canadia to europe. what is the easiest way of hooking it up so that it either auto detects the right voltage (230 V AC or 120 V AC) or can be switched easily using a manual switch. Thanks for any help Joe |
#2 |
use an IEC power cord connector so you can swap power cords and use fuse holders as jumpers to change the primary connections. You need to change fuses when you change input voltage anyway. |
#3 |
Ok Thanks, i hadn't considered using the fuse(s) themselves as the conversion mechanism.
Cheers Joe |
#4 |
Did it Himself
Just buy a proper voltage selector switch. If you have to change fuses inside the case to set voltage, nobody but you is going to know what voltage it is set to as there is no indicator, unlike the proper switch.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#5 |
Actually, i am now wondering if i can combine an automatic switch into a soft start, to make it idiot proof.
#6 |
Idiot proof would be a 100-240 VAC 47-63 HZ power factor correction SMPS.
#7 |
true, but i'd like to use what i have and i also was under the impression that a SMPS had significantly higher RF noise production.
#8 |
Look at the attached scan, this is not what you are exactly looking for, but might give you an idea on how it can be done. Two relays driven by opto-couplers can do the job. Make sure that only one relay runs no matter what input voltage is present, I mean 110~127V or 220~240V.
| Does my Onix OA21 have Dual Primaries 120-230? | samhill | Solid State | 4 | 7th June 2010 09:45 AM |
| Switching 230 Volt Transformer to 120 Volt | OMNIFEX | Parts | 10 | 6th April 2008 04:34 PM |
| audio switch automatic | palmmed | Everything Else | 3 | 18th March 2006 11:53 PM |
| Convert 230 VAC amp to 120 VAC?? | chuck55 | Solid State | 8 | 7th February 2006 01:22 PM |
| trafo change 120 to 230 v?? | partyjups | Instruments and Amps | 3 | 28th April 2004 10:15 AM |
| Page generated in 0.09515 seconds (74.00% PHP - 26.00% MySQL) with 11 queries |
