I need 15 volts regulator from 40 volts DC - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 31st May 2011, 07:28 PM   #21
BrianDonegan's Avatar
It definitely does not feed higher than the set output voltage during startup or shutdown. It would make it a pretty ****-poor component if it did.
Old 31st May 2011, 07:37 PM   #22
sofaspud's Avatar
Well, now that is an issue. With some applications NS does advise a "kickback" diode across the reg. To shunt capacitor voltage and prevent it bleeding into the output. I believe this is true for all the 317/78xx regs. But it has nothing to do with previous posts.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 31st May 2011, 07:41 PM   #23
I thought that is what you referring to with the term "lag."
I will also add, that the LM317/337 have much better noise performance than LM78xx regs.
Old 31st May 2011, 07:52 PM   #24
sofaspud's Avatar
Post #20 referred to the output lagging the input 0 to V+. Post #22 referred to the output lagging the input V+ to 0. I guess we'll drop the other false alarms.
DC heater voltage 6 volts or 12 volts? speakerfritz Tubes / Valves 7 8th October 2010 03:59 PM
power transformers 220 volts to 110 volts garydmd Chip Amps 3 7th April 2007 02:52 PM
LM3886 at 40 volts ?? ashok Chip Amps 11 29th November 2006 11:18 AM
Why is 40 volts DC comming out of my amps left channel? sound_prodigy Solid State 4 14th March 2006 05:44 PM
Gainclone is on 120 volts will it be fine at 220 volts? Jimmy154 Chip Amps 7 29th June 2005 12:10 AM
Copyright 1999-2017 diyAudio
