Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th April 2011, 11:22 PM   #1
Default Low cost compact power supply for sub-mini tube preamp
Hi, I'm interested in building a guitar tube preamp using sub-mini tubes. Some are max plate 60V and some are 165V. Any thoughts on the best approach for compact low cost power supplies for these two different voltages (two different projects, so a 60V PS for one, and a 165V PS for the other). The power supplies need to be compact as they need to fit into guitar pedals, and they need to be low cost otherwise I might as well use a lower voltage tube to start with. Thanks in advance for any thoughts.
Old 2nd May 2011, 09:37 AM   #2
mastodon's Avatar
Due to the limited space, you might try something like this: heesch.net - Schaltnetzteil für Röhren It's a small form-factor and very simple SMPS using a microcontroller to generate the switching frequency and to drive the switching mosfet. You can easily adapt the design to your needs by adjusting the transformation ratio (you'll probably wind the transformer yourself anyway).
Old 2nd May 2011, 03:53 PM   #3
Hi Mastodon,
That looks interesting. I don't speak German, but I used Google Translate to read the website, it's not perfect, but I get the idea, with the schematic as well.
Not sure about the transformer pot core though, I haven't wound my own before.
Have you built this circuit yourself? Can you specify a suitable pot core? Maybe a supplier as well if you know one :-)
Thanks for your time. John
Old 2nd May 2011, 04:11 PM   #4
Boofers is offline Boofers  Canada
If you put 120VAC straight to a bridge rectifier and filter cap you end up with around 170VDC. You could then use series resistor and second filter cap to drop the voltage down to 65VDC. Just make sure you fuse the 120VAC lol.
Old 2nd May 2011, 04:30 PM   #5
Hi Boofers
Slight problem there, I live in the UK & the mains voltage is 240VAC!
Old 2nd May 2011, 07:14 PM   #6
Originally Posted by johnmac0117 View Post
Hi Boofers
I see... Move to Canada? LOL. I guess that a step down transformer will take up too much space for you?
Old 2nd May 2011, 07:22 PM   #7
alfiax is offline alfiax  United States
No no no no no no no no no no no no no no no no no no bad bad bad. Transformer isolation or nothing. I don't think whoever finds you will be loling while he/she breaks your ribs in a (futile) attempt to get your heart started again.
Old 2nd May 2011, 08:06 PM   #8
If you have a 1:1 isolation transformer you'll still have the risk of 120VAC on the secondary.
Old 2nd May 2011, 08:25 PM   #9
120 VAC on the secondary, yes, but 120 isolated VAC which will not form a circuit through you if you become connected to ground. Isolation is an absolute requirement for any line-powered DIY device.
Old 2nd May 2011, 10:16 PM   #10
Hey I agree safety first always, but most amps still have the common on the secondary tied to earth/chassis.
preamp supply LOW power LOW noise LOW cost drdagor Power Supplies 1 13th September 2010 11:39 PM
Made in China,low cost,high quality,electronic components,power supply etc hang Vendor's Bazaar 1 16th September 2009 12:44 PM
Low cost BL mini horn with Visaton FR10 widowmaker Full Range 19 19th July 2009 07:59 PM
low cost, small, safe bias supply I_Forgot Planars & Exotics 36 1st June 2006 02:57 PM
Page generated in 0.10499 seconds (77.21% PHP - 22.79% MySQL) with 10 queries
