1000W SMPS Based on IR2110
Old 18th July 2012, 06:09 PM   #51
mikilele is offline mikilele  Serbia
Hello Hadi,
just for reference, you can check out
Switchmode Power Supply For Car Audio,
it is a good starting point for DIY car SMPS, well explained...
Old 22nd July 2012, 05:09 AM   #52
Hadighorbani is offline Hadighorbani  Iran
Originally Posted by mikilele View Post
Hello Hadi,
thanks
Old 22nd July 2012, 01:28 PM   #53
chas1 is offline chas1  Dominican Republic
Send a message via AIM to chas1 Send a message via MSN to chas1 Send a message via Yahoo to chas1
The construction of the transformer is very important, if using an ETD type core set the primary current might require you to gap the core if not it will saturate quickly and result in the mosfet's overheating and fail.The rest of the design is a straight forward DC-DC converter design.
seek and you shall find
Old 22nd July 2012, 04:27 PM   #54
Kv3audio is offline Kv3audio  India
Banned
Hypex are using the Gapped Core trick
Old 29th July 2012, 09:16 AM   #55
Terry Given is offline Terry Given  New Zealand
SMPS designers refer to this topology as a "dc transformer". its NOT a buck-derived converter, which is why there is no output inductor. startup is an absolute nightmare for this topology, but it does have the advantage of operating open-loop. there is a reason why buck derived converters have an inductor....
If one winds a really good transformer, has a top-notch layout (hint: this one isnt, but its a lot better than some of the commercial versions I've seen) and wicked low ESR output caps, the topologies inherent problems get much worse. I think the real advantage of this topology is that it works better when done badly. high leakage winding, planty of loop inductance in the secondary layout and a soft-start on the primary will give a circuit that actually works.
Old 8th August 2012, 01:42 AM   #56
davidguo is offline davidguo  China
verry good!!
Old 14th September 2012, 03:16 PM   #57
clocktower is offline clocktower  United Kingdom
Banned
any plans of showing the final schematic and protection?
Old 28th September 2012, 03:29 AM   #58
Old 29th October 2012, 02:00 PM   #59
sonsom is offline sonsom  India
Hi
For 220V input AC can I modify input turns to 22-0-22 without any other modifications. This is a very nice design which I was looking for a long time.
Kindly help.
Sony Soman
New Delhi
Old 29th January 2013, 04:51 AM   #60
billu is offline billu  India
hi..how the regulation work..dont c any feed back ..any short circuit protection
1000W SMPS Based on IR2110Hide this!Advertise here!
car smps based on TL494 himanshuraval Car Audio 54 5th January 2013 02:45 AM
need help to build my own smps based on blaupunkt schematics gta400 please Ground Zero Car Audio 148 19th August 2011 01:03 PM
Need SMPS circuit for LM3886 based audio amp pradeeppk Power Supplies 97 24th May 2011 07:20 PM
Need urgent help with SMPS SG3525 based mastero Power Supplies 22 9th August 2006 12:30 PM
Car poweramp SMPS repair TL594CN based design, help! Puggie Power Supplies 3 2nd August 2006 08:21 PM
