sorry the seniors want to get the lay out to supply class AB power amplifier .... Please help??
#2 |
Could you maybe be a little bit more specific?
Do wizards use spell checkers? |
#3 |
#4 |
What have you got?
What do you need?
regards Andrew T. |
#5 |
I'm good mr scheme and lay out of class AB power supply?
If not, the scheme only? thank you kindly mr?? |
#6 |
I understand you're looking for the schematic for the power supply for a class AB power amplifier. Is that correct?
If so, then it would be helpful if you answered this essential question: what power requirements does your amplifier have? I.e.: what voltages, and how much current per voltage? It would also help if we knew the design of the amplifier itself, so any additional requirements can be inferred from the design. In short: post all information you have, and the people here will try to help you as well as they can. |
#7 | |
I want to make a class AB power amplifier .... and it also planned new mr? |
#8 |
just another
#9 | |
| Hagerman Bugle power-supply or for +/-15dc 100ma generic supply. | tweakk | Swap Meet | 3 | 23rd February 2011 06:46 PM |
| U.S.AMPS 100HCA Power Supply Turns on 3 secs then looses Power | Kip McGee | Car Audio | 8 | 29th September 2010 04:56 AM |
| DIY Audio Alchemy Power Station 2 Power supply PSU with case | roscoeiii | Swap Meet | 2 | 29th May 2010 06:51 PM |
| LTspice tool for power amp power supply component evaluation | andy_c | Software Tools | 2 | 23rd August 2009 05:10 PM |
| heater supply (xformer specs are 6.3V 2.5A) as supply for a power LED? | jarthel | Tubes / Valves | 10 | 21st July 2003 01:30 PM |
| Page generated in 0.10149 seconds (73.92% PHP - 26.08% MySQL) with 10 queries |
