I have (had) a dead TV. I was checking power supply. I got 12V, 5V. When I checked the 24V backlight supply + to ground with my meter, I got a spark and the backlight turnded on. There was no arcing or wires touching, it was a pin to pin test. Could I have surged or spiked a lazy capacitor etc?
#2 |
I dont know but you can check the ESR parameter of capacitors, is common that capacitor wich works in hig frecuency and current (as motherboards and power supplie switching) increase the Equivalent Series Resistence (ESR). Here one schematic for made yourself Capacitor ESR Tester *see the final paragraph, very interesating. And finally, excuse me for the english, im from argentina and not know type correctly in english. Bye! |
#3 |
Could have been a poor solder joint and applying a little mechanical persuasion with the meter probes re-established contact, or as I've seen many times there is likely a failing cap(s) in there. Replace any that appear swollen, with the next higher voltage rating if they fit. Did this last night to a dead TV my parents gave me. Works beautifully now.
---Jason Kuetemann--- The greatest trick the Devil ever pulled was convincing the world he didn't exist; and like that, he's gone. |
#4 |
Inspect the solder around those pins under some magnification.
Not impossible maybe, but unlikely that you "jumpstarted" anything. |
#5 |
A bad contact is the first thing that comes to mind. Another possibility is as Andrew stated that you jumpstarted an oscillator that drives the backlight. These typically operate at a few kHz and some are relatively simple discrete circuits. But then you'd still remain with the question why the oscillator doesn't start by itself, so you'd have to troubleshoot that problem.
#6 |
i used to work in a flat screen tv place, and there was a noted problem with the high voltage backlight transformers........they were using very very fine magnet wire, and often it would snap away from the connection, or be only intermittently connected, and certainly your spark could have been from this HV.
We had to do a test to see if it would cause a fire. We had to physically break the magnet wire, and see what happened....... we found that the voltage went very high as it tried to light the backlight, but it hiccuped on and off as it kept realising that the backlight was not lighting........even though we had broken the connection, the voltage was so high that it crept along the surface of the bobbin, and carbonised it to keep remaking the connection by itself.......so basically it kept sparking away but did not ignite anything. |
| Troubleshooting and Repairing Switch Mode Power Supply | holper | Power Supplies | 1 | 12th March 2011 03:22 AM |
| connecting a switch mode power supply | peace brainerd | Parts | 5 | 24th April 2008 11:32 PM |
| Switch Mode Power Supply | john65b | Power Supplies | 4 | 22nd March 2008 05:59 PM |
| to all the switch mode power supply divas | mikechamboko | Power Supplies | 1 | 1st March 2005 08:24 PM |
| Switch Mode Power Supply | tschrama | Power Supplies | 5 | 22nd October 2004 02:39 AM |
| Page generated in 0.08937 seconds (73.99% PHP - 26.01% MySQL) with 10 queries |
