#11 |
hello sir .
looking very nice ... thank u ...
http://http://www.facebook.com/profile.php?id=100000413405389 |
#12 |
not only does it look nice it works even nicer....................... the best part when u dont have to invest in bulky transformer and huge caps ..................
regards phoenix |
#13 |
what about multi o/p like +/-55 and +/-110 or +/-70 with 2200-3000watts ?
anybody build ? i'm very interested with that SMPS. |
#14 |
I think the cooling fan should be temperature controlled an not necessarily voltage regulated. Audio amps spend most of their time at fairly low power levels so a cooling fan shouldn't be needed very often. Excellent job on the layout and design.
#15 |
Hello,
Nice job. Now lay out of pcb if you don't mind, So we can etch our own board and try this fantastic design. Thank you |
#16 |
You have an interesting way of driving the top FET in this design. I am not sure how the conduction timing is controlled to prevent both FETs being on during switching. I am thinking since it is transformer driven the top can't turn on until the flux starts to change in the transformer. Clever, if that's what is happening. Is this a common?
#17 |
sorry guys a bit late .......................... busy with the new pcb release of the smps neways currently i can give a double sided board layout for this smps with a pfc .......
any body interested ........... i am currently working on the single sided board its gonna a bit of time........ regards phoenix |
#18 |
wanna sneak peak at the single sided board...................
#19 |
so here it is
regards phoenix |
#20 |
If you try to find a fool, the first person you find is yourself. |
| design & build 300w ot & pt | coreythompsonhm | Instruments and Amps | 9 | 2nd October 2012 08:54 PM |
| 12v 6BF7 preamp design tested | unclejed613 | Tubes / Valves | 9 | 5th November 2007 11:23 AM |
| FS:GAMUT D200 MKIII clone fully assembled & tested | ANALOG GUY | Swap Meet | 0 | 31st July 2007 08:09 AM |
| Fully complementary FET-in FET-out design | Bensen | Solid State | 36 | 7th January 2006 09:21 AM |
| Tried and tested clone or design for 10w valve amp. | kazino21 | Multi-Way | 6 | 4th March 2005 05:48 PM |
