Go Back   Home > Forums > Amplifiers > Power Supplies
Old 18th April 2011, 05:04 PM   #1
vasko is offline vasko  Czech Republic
Default Frequency generator 50-100kHz IC?
I need IC on 12V to drive two bipolar transistors in push-pull on 50-100kHz with ferrit transformer?
I don't want full smps with feedbacks functionality...something more simple just to drive transistors. Also need schematic? Is it possible to accomplish this with simple 555?
Old 18th April 2011, 05:07 PM   #2
Do you need a sine wave or square wave (switching) output?
What power levels are you attempting to drive, in your push-pull pair?
Old 18th April 2011, 05:09 PM   #3
1. square
2. 30 - 100W
Old 18th April 2011, 05:21 PM   #4
Check the link. Intersil Corporation
Hope this solves your need
I mean this IC as a building base. you can connect this to any wide band power amplifier.
There is always a first time....
Old 18th April 2011, 05:29 PM   #5
I don't have +/- 10V voltage. I have 12V only. Also don't need sine or triangle waves.
Something like this,just not 50Hz,but 50-100kHz.
Old 18th April 2011, 06:16 PM   #6
Mooly's Avatar
A problem with such a simple circuit is device conduction overlap or cross conduction as the output devices do not turn off abruptly. In other words both transistors will be on together for a significant time leading to large losses and heat generation. You really need some form of dead zone where both devices are off but that involves extra logic unless you research some off the shelf SMPS drivers.
A simulation free zone. Design it, build it, test it.
Old 18th April 2011, 06:25 PM   #7
Is there some simple schematic with TL494?
Old 18th April 2011, 06:40 PM   #8
Mooly's Avatar
To design something like this properly is quite a job... however if you are just experimenting then by all means try something like you have shown.
I wonder whether FET's would work better as switching devices due to the low current drive available from the CMOS oscillator.
Something like this for a full design maybe,
http://www.fairchildsemi.com/ds/KA/KA3525A.pdf
Old 18th April 2011, 06:58 PM   #9
is this the simplest it can be?
Old 18th April 2011, 07:44 PM   #10
agdr is offline agdr  United States
agdr's Avatar
Here is a circuit like that: 12V DC to 220V 100W Inverter with 4047 IC & IRF540
FS: 100kHz Function Generator kit transducer Swap Meet 1 21st September 2011 02:33 AM
FM/AM Frequency Generator Recommendations Black Gate Equipment & Tools 11 12th February 2010 11:24 PM
Frequency generator software REALFLEO Parts 5 7th December 2006 12:39 PM
Frequency Generator Bryan Parts 10 17th March 2004 05:39 PM
MAX038 Function Generator IC? hifiZen Parts 40 26th December 2002 08:51 PM
Page generated in 0.08543 seconds (86.06% PHP - 13.94% MySQL) with 10 queries
