Hi
I'm in the process of designing a simple power supply for a TA2024 class-t amp, which needs a 12V fixed supply. I've salvaged an old Transformer from a battery charger and measured its RMS output to be 12.8V. My plan is the following circuit:- Transformer(12.8Vrms)->Full Bridge Rectifier(~16V)->Smoothing Caps->7812 Regulator(2A max) Now I read that a large capacitor bank is good for audio response, so does having only the capacitor bank infront of the rectifier matter? Or should I put an additional Capacitor after the Regulator. For what its worth I'm making this a quick build and I have 4x6700uF caps on hand only. Any advice is greatly appreciated, Matt |
#2 |
Capacitors before the regulator.
Regulator must be able to supply the peak current draw of the amplifier. Decoupling capacitors should be used near the amplifier IC. |
| 18V AC+ 12V AC to +/-15V DC?? | Elbert | Power Supplies | 8 | 24th July 2010 06:10 PM |
| chip amp with 12v DC AND 240v AC power supplies? | Vital AV | Chip Amps | 19 | 15th November 2009 10:39 PM |
| 12v dc to 19v dc and 110v ac | shadiedog87 | Power Supplies | 0 | 18th December 2007 02:57 PM |
| Easy PSU question - help me make this 12v DC power supply better. | owdi | Power Supplies | 8 | 2nd May 2007 04:42 PM |
| 12V-220V(ac) to 12V-50V(dc) | raszvan | Car Audio | 0 | 16th June 2005 08:28 AM |
| Page generated in 0.07597 seconds (73.30% PHP - 26.70% MySQL) with 10 queries |
