Go Back   Home > Forums > Amplifiers > Power Supplies
Old 12th April 2011, 08:45 PM   #1
acidbrain's Avatar
Default earth grounding questions when using shielded cat5 & neutrikplugs
Hi fellow Diyers,
I have a question about earth grounding my system.
-All signal grounds are floating in each cabinet and star connected in the pre-amp. At that starpoint is a connection with the mains earth through an isolator.(2 diodes/ R & C)
-Each cabinet is connected to mains earth at my UPS in starconnection.
I realized that I have 2 shielded Neutrik cables go from one chassis to another chassis, both are on each side connected to the chassis and therefore connected with the mains earth, cousing a loop. Not only between them but also with the earth. The lenght of both cables is just 40cm.
Do I have to cut both cables shields at one end ?
The same thing with my cat5 shielded cable, I can connect both shield-ends to the 2 chassis. Should I just connect one end of the cable to earth to prevent a groundloop ?
This is not a signalgroundloop, but it doesn't look healthy to me.
Anyone who can help me in the neverending story of grounding ?
Old 13th April 2011, 12:22 PM   #2
Davenport in Articles.
regards Andrew T.
Old 13th April 2011, 02:22 PM   #3
acidbrain's Avatar
Very informative article indeed, but I can't find anything about the behaviour of parallel safety grounds. I just cut all ends at one side, to get rid of any loop.
Old 21st April 2011, 12:06 AM   #4
Speedskater's Avatar
No, don't cut the shields, it truth they are good. Tony Waldron sometimes writes about them. He calls them PEC (Parallel Earth Conductor's) they should all follow the same path and be about the same length. In Recording or TV studios, the more the merrier.
Kevin
Old 21st April 2011, 07:45 AM   #5
acidbrain's Avatar
Hi Kevin, I googled on PEC and found a lot of info about old and new ways of earthing equipment. It looks like I can(must) earth both ends, but I need to add a PEC between the cases to minimize the earthloop. Hmm, maybe not in the case where I use already 2 Neutrik cables only with the single cat 5.
Thanks for getting me on the right path
Bonding Cable Shields at Both Ends to Reduce Noise
Designing for Interference-free Audio System Components
http://www.vanderheide.nl/documents/...ntHandler.ashx
Grounding: Earth and Center Tap whitelabrat Everything Else 11 11th April 2012 07:09 AM
DIY braided CAT5 questions Khron Multi-Way 3 16th December 2008 11:00 PM
Grounding & board Layout questions Valvomaniac Tubes / Valves 1 26th April 2007 03:56 AM
Questions about making Cat5 speaker cable wixy Everything Else 1 10th March 2007 06:57 AM
grounding & power supply questions timsch75 Chip Amps 2 15th January 2004 05:04 PM
Page generated in 0.08395 seconds (84.83% PHP - 15.17% MySQL) with 10 queries
