Hi everyone,
Recently I constructed a fet based pre amp for my guitar. The sound performance seems good and overall I am happy with it. However, I was somewhat disappointed initially with the background noise it produced - almost a white noise/hissing sound. On a hunch I swapped the power supply (its one of those multi-voltage ones where you can select a number of different voltages from 1.5-12V) for a 9V battery and the noise disappeared. Good times. However, I would like to continue to use my DC power supply and perhaps others which could be just as noisy. I would like to keep the circuit as simple as possible, therefore my question is this: How can I clean up a power source using non-regulated techniques initially then if this doesn't work what regulated circuits have people used? Thanks! |
#2 |
Does your circuit have any bypass capacitors for the supply? If the noise is hiss, bypasses and maybe a bit of series resistance should take care of it, depending on exactly where it comes from.
I used to be an audiophool like you but then I took an arrow to the knee. |
#3 |
It probably comes from the switching regulator. Does the adaptor look something like this?
MW 2006GS | GES-ELECTRONICS Then it is a SMPS and some LC filter should help get the noise down. |
#4 |
Thanks for the messages!
Conrad, I have a capacitor but no series resistance. Am I right I thinking that this creates a low-pass filter? If this is the case then I believe my cut-off is too high (the capacitor is only 10uF) hence why I can still hear the noise. If I were to use a resistance of 100ohms and a capactor of 100uF then this would set the cut off at about 15Hz? Kubeek, yes its very similar. Say I use a 100uF cap, would I be correct in saying that using an LC filter could produce the cut off required without needing the such a high series resistance? In my comment above I said I could use 100Ohms which seems a little high? |
#5 |
LC means inductance with capacitance, which will be far better. If you donīt have access to a suitable inductor, you can use RC filter.
You donīt say how much current does your amp need, but the 100ohm resistor would limit the current to 120mA. I would use something smaller, like 10ohms, which with the 100uF cap will make a 160Hz low pass filter, which will attenuate -42dB at 20kHz and that should be enough. If it is not, you can split the resistor into two 5 ohms and make a two-stage filter with two caps, connecting it R-C-R-C, which will yield -70db attenuation. If you got different caps, use the larger as the first one, preferably with a 100nF ceramic one in parallel. |
| Regulator IC application | lauret | Power Supplies | 1 | 25th October 2008 12:52 PM |
| IC Power regulator | sandmaniac | Solid State | 2 | 16th July 2007 10:03 PM |
| 3-terminal regulator IC protection | metebalci | Parts | 0 | 4th May 2004 08:46 PM |
| Regulator IC Data - LAS19U | JDeV | Parts | 9 | 24th May 2003 10:01 AM |
| Best IC voltage regulator.... | DanK | Solid State | 22 | 11th November 2001 06:33 PM |
| Page generated in 0.09592 seconds (74.71% PHP - 25.29% MySQL) with 10 queries |
