SMPS IR2153 vs ATX transformers
Old 25th June 2012, 06:53 AM   #51
Kv3audio is offline Kv3audio  India
Banned
I have few questions:
1) Is my board good for this smps?
Looks just fine for startup project DIY
2) I can find in my country ETD49 core 3C90 and ETD49 core 3F3, which of these can I use, same question is for EE16 for curent sens?
I dont know about EE16, but 3C90 and 3F3 are best for SMPS, being used all over.
3) Do I need air gap on central leg?
hmmm, you have to ask HYPEX about this question indeed.
4) I dont know number of turns and wire ticknes for primary and secondary (I need +-50V)
Use calculator
5) Number of turns for EE16 current sens transformer and wire thickens?
I dont know about this!
Good Luck
Old 25th June 2012, 10:15 AM   #52
Dzony988 is offline Dzony988  Serbia
Thank you Kv3audio
Old 29th August 2012, 08:04 AM   #53
stewin is offline stewin  Kenya
hi guys any progress?
Old 3rd May 2013, 06:53 PM   #54
hi dzony did you manage to get your smps to work ? try the below links for answers
diysmps)
diysmps
diysmps
diysmps
Old 11th July 2013, 05:07 AM   #55
eusebio pacheco is offline eusebio pacheco
hola compañeros tiene un esquemático de esa fuente que habla el amigo ap2 me gustaria para poder construirlo pues el comenta que es muy estable saludos desde colombia espero su respuesta
English please. Rules,
diyAudio Rules
Hello fellow has a schematic of this source which speaks the friend ap2 I would like to be able to build it because the comments that it is very stable greetings from colombia, I hope your answer
Old 21st May 2014, 07:10 AM   #56
vgeorgiev is offline vgeorgiev  Bulgaria
Let me hijack this thread.
I did this setup Jednoduchý neregulovaný zdroj 2x 35V 2x 5A 350W pro zesilova?.
However it is not working.
I am using IR2153D. So I omitted BA159 diode.
On the first try I used a 60W bulb in series to the mains in order to avoid any blow up
Then I removed the bulb and ran the circuit directly.
I was not soldered the rectifier on the secondary. Just wanted to measure the AC on the secondary.
I got 50V on the secondary winding on transformer. After 1-2 second the voltage was 0V. After another few seconds it was again 45-50V.
Then I soldered the rectifier and ran the circuit again.
No success this time. 0V DC on the output.
Then I tried to debug it.
I have 0.25V on the gates on both mosfets.
I got 9V between pins 1 and 4 on the IC.
I think it should be 16V.
Do you have any clue ?
Old 21st May 2014, 10:35 AM   #57
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
At 9v the IC goes to "undervoltage lockout".
Why do you have only 9v at pin 1?
Is the resistor Rvcc (27k 6W in your schema) OK?
Old 21st May 2014, 10:53 AM   #58
Thank you for your prompt answer!
Used 22K/5W resistor.
Rectified voltage is DC 310V.
That makes 13mA current. I think is should be enough to operate the Zener Diode (inside the IC) at 15V.
I will de-solder all the connected pins but pins 1 and 4. Then I will measure the voltage across the IC.
If it is not OK then I will provide external 15V to feed the IC.
Let you know about the results.
Old 1st June 2014, 02:50 PM   #59
As I ezplained the schematic is as follows:
Attached 40W incandescent lamp in series with the mains in order to prevent any issues.
In addition I put 0.47 Ohm 5W resistor in the source of LO side MOSFET in order to measure the current flowing.
I am using ATX PSU transformer.
Attached 12V bulb as a load to the secondary.
OK. Powered up and it worked.
However after few attempts the circuit stopped working.
I measured 8.9V between pins 1 and 4 of IR2153D.
Beside that I had build following circuit in order to test the IC.
After the SMPS failed to work I moved the IC to the test circuit. And it was not working.
OK. Replaced the IC with new one.
It worked several times and failed again.
Pin 7 is switching but pin does not.
Anyone has any clue ?
Old 2nd June 2014, 12:39 AM   #60
toyer is offline toyer  Turkey
whichone is switching on whichone is not?
on datasheet for the ir2153d the connection is a bit different. i have no idea if it is the cuz but just check it.
SMPS IR2153 vs ATX transformersHide this!Advertise here!
Halfbridge SMPS with IR2153: Different Halbridge Topologies? batbat Power Supplies 5 27th November 2009 04:41 PM
IR2153 sub SISKO Power Supplies 0 10th May 2008 02:15 PM
Ir2153 m-tech Power Supplies 2 15th December 2007 01:02 PM
Using ATX PSU trans for 12V SMPS? EWorkshop1708 Power Supplies 4 1st January 2006 03:53 PM
