#31 | |
or you mean dc output to dc low voltage? also this have clearance. Last edited by AP2; 23rd August 2011 at 03:24 PM. |
#32 |
I was looking at the PCB picture on page 1, I couldn't see no obvious space between the high voltage area and the rest.
#33 |
#34 |
Hi Roberto (AP2) !
Please if you are able to set a schematic, PCB-layout and parts list of your SMPS, or sent me on my E-mail. I need this SMPS (2x35V/2x5A) for the stereo amplifier with TDA7294/4om! Advance thanks for the great help! Last edited by radio; 24th August 2011 at 05:14 AM. |
#35 |
The layout on page 1 post 1, I would say does not conform to required creepage and clearance distance, wich with the voltages present and working to worse cass class 111 polution should be 4mm clearance and 8mm creepage, or 4mm with a 1mm or wider slot in the PCB to ensure an 8mm creepage distance.
Sorry AP2 I wasn |
#36 |
Sorry AP2 I wasn't refering to your layout.
#37 | |
ok, I put project in this thread at weekend. maybe can help others diy. for sub is very good (600-700w) Regards |
#38 |
Ok this is main schematic and new layout of PCB. Do anyone have idea for shorst cutcuit protection without curent transformer or curent sens on primary side. Even maybe is better schematic or sugestion with other ic (TL494 on exapmle) but with ATX transforemers in serial for +-50V.
I dont know indutance of that transformer or ratio but on primary side it has 30 turns and on secondary it has 2x7 turns with central GND for 2x12V but in serial its almost 25V. Core is EI 33 without gap Can one TL494 and one pair of mosfet "push" two of these? |
#39 | |
now pcb is better but not perfect, some layers need modify. your trafo (pr=30:sec=7) with ir2153 circuit, produces 36,9V per side @ 230 Vac. also, requires low frequency of switch, around 40Khz max. regards |
#40 |
On example, can I use this layout but two atx transformers (primary in parallel and secondary in serial)
Or do you have schematic of GOOD smp 600-700W 2x50-60VDC. I need for amp D class (for subwoofers) |
| Halfbridge SMPS with IR2153: Different Halbridge Topologies? | batbat | Power Supplies | 5 | 27th November 2009 04:41 PM |
| IR2153 sub | SISKO | Power Supplies | 0 | 10th May 2008 02:15 PM |
| Ir2153 | m-tech | Power Supplies | 2 | 15th December 2007 01:02 PM |
| Using ATX PSU trans for 12V SMPS? | EWorkshop1708 | Power Supplies | 4 | 1st January 2006 03:53 PM |
