Hello,
does somebody have idea,..how to protect 2 Mosfets IRFP250N and IR2110 (Class D output stage) if short circuit happenend ? Rail is about +/- 85 V DC have see shunt resistor in positive and negative rail as current sensing...any other working ! effective ideas with low component count other designs have only shunt resistor in positive as current sensing |
#2 |
Sunt in positive or negative rail for curent sens is not good idea because you use low rds fets and output inductor and with adding a shunt you all srew up because for optocoupler or other things you need 1-1.5V drop on positive rail, this menas you add more resistion on your low rds fets and output inductor. If you have any idea post here..
#4 | |
Phillips using in UCD reference design...and IRF shunt resistors too. Crest using in Half Bridge Class D Amplifier with (IR 2110 IC and APT Mosfets) shunt resistors for current sensing too regards |
#5 |
here, from TR3 to IC6A. Event though this is a PSU, the protection can also be used in class-d output stages.
| Biasing of IR2110 Mosfet Driver | Razor_Edge | Class D | 16 | 20th July 2006 12:09 PM |
| Page generated in 0.09563 seconds (72.02% PHP - 27.98% MySQL) with 11 queries |
