Thin ice but I have 62V power rail in subwoofer and only 63V (10,000uF) rated caps around to do "quick & dirty" repair . The caps are respected Nippon-Chemi-Con and they are replacing some bubly 100V chinese jobs. Not perfectly comfortable situation and I wonder how long the new caps have a chance to play being exposed to almost 100% rated voltage. TIA
#2 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
The chances of it "playing" will be a matter of minutes..........It might up & just 'blow' when you first power it up.
Find the 100V version.........you will just be wasting your time, effort & a handful of caps. _________________________________________________R ick.......... |
#3 |
just another
The main problem likely to be faced is mains fluctuations. If your mains goes 10% over (certainly within the realms of possibility) then you will be running them at around 68V. 75V or 80V caps should be considered as a long term repair, 100V seems a bit of overkill for 62V rails
Tony. |
#4 |
just another
Just saw Richard got in before me, the comment about 100V was related to the 100V originals not to Richards comment. My general rule of thumb is 20% over rated as a minimum. If there is no huge cost (or size) penalty going to 100V then there is no harm in having the extra safety margin
Tony. |
#5 |
I agree with Tony. If the cap is rated at 63 volts and you never give it more then 63 volts it should work flawlessly for the specified life span. A well made 63v cap isn't exactly going to explode either if you go over this value by a volt or five, however I would expect it's life span to suffer as a result. Depending on the variations that you can expect on the mains line, this might go a bit too high beyond a comfortable limit. If you want, check the voltage that the cap will be subjected to say at midnight, this shouldn't be too far away from a realistic maximum
The cheapo Chinese caps could be a good example of using an underspec'd cap for a specific job. They don't explode, but they don't exactly last long.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#6 |
OK , I put them in and they play comfortable for a few hrs. My main is already high at 123V so it's unlikely it will go higher. I will source 80V ones or so once I'll be making an order or something pops out. So far so good. Thanks ya all
| WTB: 4 - 22000uf 63v filter caps | el34guy | Swap Meet | 0 | 28th December 2009 07:40 PM |
| Which 15000uf 63v caps?? | nad | Solid State | 18 | 7th December 2009 06:12 PM |
| 10,000uf 63v caps $5.00ea | Zero Cool | Swap Meet | 1 | 29th June 2005 05:23 PM |
| Help, source for 100.000MF/63V elco caps? | JC Fardo | Parts | 10 | 26th June 2004 05:16 AM |
| 5,600/63V Nichicon caps for sale | Peter Daniel | Swap Meet | 3 | 21st March 2003 01:22 PM |
| Page generated in 0.08109 seconds (77.25% PHP - 22.75% MySQL) with 10 queries |
