Go Back   Home > Forums > Amplifiers > Power Supplies
Old 31st March 2011, 04:21 PM   #1
Unhappy need help building a switching power supply for car amps
i have just built a switching power supply . project 89 of rod elliots website http://sound.westhost.com/project89.htm. i have some doubs abot the transformer. .. what can be the effect of using different sizes of cores rather that 39 for 360W
please tell me.
Old 1st April 2011, 09:55 AM   #2
Send a message via Yahoo to Th3 uN1Qu3
Larger core needs less turns so you can use thicker wire and get higher current thus higher power.
"Audio grade" components simply means that they failed at a more critical job.
Old 1st April 2011, 03:07 PM   #3
thanks alot for the answer.
i just wanna know is there a way to calculate the rate of turns and power exactly with different core sizes.
and how can i calculate the dia of a wire when i know the current and voltage?
Old 1st April 2011, 07:04 PM   #4
Of course there is a way. There are lots of books on it... The ones that helped me the most are "Switching Power Supply Design Third Edition" by A. Pressman and K. Billings, "Power Supply Cookbook" by Marty Brown, and "Switching Power Supplies A to Z" by Sanjaya Maniktala.
I have some "cheat sheets" i wrote which do most of the work for you but i'll only send them to you if you show me you actually looked into those books i mentioned.
Old 3rd April 2011, 04:09 PM   #5
Post these books avalible???
those books maybe unavalible for me.
can you give me a link for the pdf files or the books some how
Split Voltage Switching Power Supply for Power Amp vectorplane Swap Meet 2 23rd April 2011 11:48 PM
Noise issues with power switching amps? Racket Scientist Class D 1 14th November 2010 09:25 PM
What power supply do I need to use the Sure Electronics T-amps in a car? blamus Chip Amps 2 21st October 2010 04:50 AM
car amps are leaving the building... Stuart Easson Car Audio 0 7th November 2004 05:04 PM
switching power supply? partyjups Solid State 1 6th October 2001 12:44 PM
Page generated in 0.07644 seconds (74.81% PHP - 25.19% MySQL) with 10 queries
