Go Back   Home > Forums > Amplifiers > Power Supplies
Old 28th March 2011, 11:20 PM   #1
Default Repair Toroid Enamel
I was modifying a toroid power transformer from center tapped to dual secondary when I got careless and damaged some of the enamel on the secondary wires. There are a few very small spots where the coating is off -- maybe 5-6 locations total. I am not very concerned because there don't appear to be any shorts and the secondary voltage is only 15V so I don't have to worry about arcing, but I still want to repair them. Some of them are on wires next to each other so they could shift around over time and cause shorts in the future.
Does anyone have any ideas? I have thought about using glue or something like nail polish to touch up the enamel. Alternatively I can unwind the toroid and use some heat shrink at each of the nicks, but I would prefer not to do this! It is a 150VA transformer so I expect it to get warm.
Old 29th March 2011, 12:16 AM   #2
AEIOU is offline AEIOU  United States
AEIOU's Avatar
Send a message via AIM to AEIOU Send a message via MSN to AEIOU Send a message via Yahoo to AEIOU
Fingernail polish is what came to my mind too! You can pick any color you want or get clear. Thin the paint if it's too thick.
Old 29th March 2011, 12:30 AM   #3
johnferrier's Avatar
At Fry's Electronics, I've seen enamel polish (for transformers). Comes in a small bottle with a brush. Not far from the printed circuit board etching kits.
Michael Gazzaniga - "The arts are not frosting but baking soda."
Old 29th March 2011, 12:52 AM   #4
Turns out it's a varnish. This stuff . . .
Red Insulating Varnish
Old 29th March 2011, 01:30 AM   #5
Sounds great. The closest Frys is a 40 minute drive, but I might try to find some varnish like that locally. Thanks for the info!
Old 29th March 2011, 01:34 AM   #6
use a clear nail polish is fine.
as long as the winding is not to badly nicked.
I did that to one of mine but the nicks are quite deep and nearly cut the wire compleatly through.
This causes a higher resistance in that spot and can cause it to fuse open but since it is on the top layer it can be fixed.
luckly I have another use for it and I don't need that winding.
no need for any expensive varnish for 15 volts. jer
Old 29th March 2011, 10:14 AM   #7
I have "repaired" the enamel with nail varnish. It worked.
I was splitting a 70+70Vac pair of windings into four windings of 35Vac each.
I needed to scrape off some enamel to measure the voltages on the secondary to find the midpoints of the windings. Snip and connect in 4 extra leadouts. Worked a charm and saved having to unwind and rewind the secondaries.
regards Andrew T.
Old 30th March 2011, 06:46 AM   #8
Ordinary household polyurethane varnish works well for me and sets harder than nail varnish. I have used a low oven (50 deg.C) to speed up the drying time, it then sets in 10 to 15 mins.
Vitreous Enamel vs Wirewound Resistor Valverine Tubes / Valves 31 2nd September 2010 08:55 AM
Retail source for xformer enamel? leadbelly Everything Else 1 5th March 2007 05:01 AM
veneer, enamel or lacquer lemans23 Multi-Way 11 16th August 2005 03:10 AM
Enamel finish bjackson Multi-Way 11 26th April 2005 07:40 PM
best way of coating bare wire with enamel? tom1356 Parts 6 10th October 2003 05:41 PM
Page generated in 0.09492 seconds (78.07% PHP - 21.93% MySQL) with 10 queries
