I scrounged a 900VA+ transformer from an old battery backup and I can't find any information on it. I have plugged it in and it trips a 120V 20A breaker every time. I am wondering about using NTC Thermistors to limit my inrush current. Would it just be easier to build a soft start circuit?
#2 |
I'd say that ICLs are probably easiest, though the on resistance could possibly be a problem if you don't have any headroom.
#3 |
The recommended fuse rating for a motor and for a transformer is
3times the power divided by the supply voltage. Your 900VA running on 115Vac would require approximately >=23.5A fuse to start up reliably. You may find that you have to use a B or C rated 25A breaker to get it to start up. Alternatively fit a soft start using either suitably rated Power Thermistors or Power Resistors. |
#4 |
I figured on using power thermistors. My breaker is a 20A Class C. It would make sense that I would trip the breaker if I was trying to pull almost 24A across it.
#5 |
Electrons are yellow and more is better!
Probably. Have you noticed my group buy?
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#6 |
No I have not.
#7 |
the transformer will be pulling a lot higher than 24Apk at start up. Have a look at the time vs current of a ClassC breaker. The transient that can pass for short periods is many times the rated breaker value. At some point in the starting sequence your transformer is taking the breaker outside the ClassC curve. It might be at the very first instant of 1us after closing the switch , or it might be after 1ms after closing the switch. More likely it is an accumulation of [i^2t] that opens the breaker. The same happens with a fuse. What you try to do is keep the current during the first few millisecond under some form of control so that the transient current limits for the chosen breaker an/or chosen fuse are not exceeded. Soft start is designed to specifically control the starting currents. |
#8 | |
#9 |
light bulb tester time. Use a 40-60W light bulb in series with the transformer. If the bulb stays on after the initial surge there is an issue with the transformer.
#10 |
I'll have to look into building a light bulb tester.
| Inrush limiting circuit | pona | Parts | 1 | 16th October 2010 09:32 AM |
| Inrush current limiting heater filaments | boywonder | Tubes / Valves | 14 | 2nd February 2009 07:33 AM |
| Inrush current limiting necessary for EI transformers | Bama Slamma | Power Supplies | 10 | 6th November 2006 05:08 PM |
| Limiting Inrush?? | Deltat | Power Supplies | 11 | 31st March 2006 03:38 PM |
| Inrush Current Limiting Circuit | haldor | Parts | 22 | 8th October 2004 03:06 PM |
