diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Power Supplies (http://www.diyaudio.com/forums/power-supplies/)
-   -   The Belleson Superpower, the ultimate voltage regulator ... ? (http://www.diyaudio.com/forums/power-supplies/185763-belleson-superpower-ultimate-voltage-regulator.html)
BMW850 25th March 2011 01:41 PM
Hi all,
These are beautiful words but this is all true what it says on the site of Belleson?
Now we have no longer to look at other brands, or is this all marketing strategy ... or are they real good what it say on the site!
http://www.belleson.com/comparealw.php
Superpower compared to a Battery
Superpower compared to a Jung style super regulator
Superpower compared to LM317
Superpower compared to LM7812
Superpower compared to Dexa NewClassD
Superpower compared to Burson
The Belleson Superpower regulator, like Mr. Jung's design, uses the regulator's cleaned and quieted output voltage as the "bootstrapped" power source for its own internal reference and error amplifier. In addition,
It is stable with the included 10F output capacitance and remains stable with larger values.
Output voltage is set with a single resistor.
Superpower fits a 3 terminal regulator footprint and can bolt directly to a heat sink.
Start-up is guaranteed—the expected output voltage is the only stable state.
Gain/bandwidth of the internal amplifier is independent of output voltage.
Drop-out voltage is as low as V at low current, less than 2V at currents to A for standard or 1A+ for the HV and J versions.
Superpower performs better without a pre-regulator.
There are no zener diodes.
Rudy
woodturner-fran 25th March 2011 11:05 PM
Neat, but not cheap!
wwenze 25th March 2011 11:33 PM
What's more interesting is the measurements of the other boutique power supplies.
MatchASM 26th March 2011 01:28 AM
I'm not convinced that this regulator is so wonderful. Its noise is specified at 28uVrms, higher than the LM317 value of 22uVrms and far higher than, say, a TeddyReg.
In the transient comparison with the LM317, no mention is made of the exact LM317 feedback configuration ("as in datasheet" could mean anything). And for the 1A transient a larger-than-standard output device is used! How about we just put multiple LM317s in parallel?
Overall, I anyhow think that the LM317 is very hard to beat, especially considering the price. I can get one from my local electronic parts shop around the corner for 1.25 Euros. For the money of a Belleson, you can put a lot of those in cascade and in parallel!
Greetz,
MatchASM
martin clark 26th March 2011 01:51 AM
There's too much missing from any of the comparisons, and the datasheet, to form any real opinion.
Ken Newton 26th March 2011 11:10 PM
It's unfortunate that Belleson doesn't feel comfortable enough to provide at least a simplified schematic so that potential buyers can better assess the novelty of their regulator design.
stormsonic 27th March 2011 12:09 AM
They can be much cheaper than 1,25€/pcs. 5,35€/20 pcs, delivered to your home adress. Original parts, not fake.
For 5€ you can buy decent opamp, pass transistor & LED's for voltage reference and make your own regulator, much better than '317.
For small quantity & DIY purposes, price is almost irrelevant. You want performance, not cheap BOM.
iko 27th March 2011 12:21 AM
LM317 is not hard to beat. A decent shunt reg will leave it in the dust. Implement the simple Salas v1.0 and then smile at the Belleson SUPERDUPER. DIY at its best. Mr. stormsonic knows what he's talking about, because he implemented quite a few regs :)
jackinnj 27th March 2011 12:58 AM
Tomorrow I'll run the LR and Z test on the Belleson.
MatchASM 27th March 2011 02:10 AM
Originally Posted by ikoflexer (http://www.diyaudio.com/forums/power-supplies/185763-belleson-superpower-ultimate-voltage-regulator-post2517683.html#post2517683)
Except if it does not fit into the available space.
For a rather high price there are some compact integrated regs available, but your 15-component custom regulator will be bulky and a good reason to learn the art of casemodding.
BTW, I have near-to-no experience in custom shunt regulators; what output voltage noise is achievable for 100uA of bias current? (far lower than 22uV rms, I hope...)
Greetz,
MatchASM
Resources saved on this page: MySQL 18.75%
