The Belleson Superpower, the ultimate voltage regulator ... ? - Page 5 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th April 2011, 02:35 PM   #41
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
I have a set of Belleson +24v (LM317 type) and will be making an external power supply for a CD player soon. I can't compare it to another regulator, but I can A/B with or without the external. Will let you know how it sounds.
Vince
I build, therefore I am.
Old 13th April 2011, 02:47 PM   #42
jackinnj's Avatar
Originally Posted by belleson View Post
You don't say how your transformer test circuit is connected, is it possible that DC current is saturating the core and skewing the measurements? This could cause errors that depend on regulator current consumption.
We use an active driven source to feed the input rather than a transformer, and are working on a PSRR test circuit that uses an LM3886 to drive the input with DC+AC.
The transformer isn't saturating -- it's good up to about 600mA DC. See Audio Precision TN-106.
I use the 1995 TAA Articles as a reference point. Jung specified a load of 100R//100uF. You may be using a purely resistive load.
I've used batteries, an HP6271B and a Tek PS5010 to drive the regulators. The HP6271 can be "modulated" but it requires de-racking it.
The output impedance of the AP2722 is 20 ohms unbalanced, 40 ohms balanced. The schematic below shows a low impedance driver WJ used for his experiments which overcome this issue. (It's a variant of the Pooge 5.1 regulator). I simmed it to be ~2.4 milliOhms. Variously, WJ appears to have used 1.4V p-p and 1V p-p, for his line rejection tests. Using 1V RMS is putting a lot more burden on the regulator, I agree.
Line rejection is easier to measure than output impedance. The noise tests use a balanced, low noise line driver set to 100X.
For the diode example you give, do you want to specify the diode and leakage inductance of the trafo you were using? Almost looks like my wife was using her hair blower!
Old 13th April 2011, 05:18 PM   #43
Originally Posted by stormsonic View Post
@belleson
post #35, second picture with measurement results: are you using HPF ?
The FFT software has a "Remove DC" selector which is active. I also believe the hardware used for this measurement has an input coupling capacitor.
Old 13th April 2011, 08:51 PM   #44
stormsonic's Avatar
Belleson, thank you very much. Yes, Visual Analyzer has a lot of options and filters.
Can you please show as a comparision plot between noise floor and regulator's output, all filters disabled (including DC removal), Hanning and Averaging=100 ?
Old 14th April 2011, 02:46 AM   #45
The low impedance driver is exactly the topology we used in PSRR tests, except of course the modulated regulator is a Superpower. The problem with this topology is the limited output frequency. This positive regulator, with load capacitor C2=0.1uF and load resistor R12=350 Ohms, can go to about 42KHz before the negative going signal starts to limit. With 1uF on the input of the DUT regulator, frequency limits at 4.2KHz, 10uF/420Hz, etc.
This is because the output has an active current source but a passive current sink limited by the 350 Ohm R12. When Vout modulation peaks and begins to decrease, R12 has to discharge C2 and any capacitance on the DUT input. This is why our PSRR measurements go only to 5KHz and why we're looking at a different driver such as LM3886, which can sink as well as source current.
At f(max), the sine wave does not degrade gracefully into a triangle but instead the low-going half-wave slew limits and decreases Vmax amplitude, distorting the measurement reference value of 1Vpp (or in your test 1Vrms).
I don't know the transformer and diode leakage inductance, it's the raw output from the rectifier in a Tripp-Lite PR-10b. The "hair blower" spectrum is typical of (approximately) sawtooth full wave rectifier ripple, only the textbooks don't show so many harmonics.
Old 14th April 2011, 03:21 PM   #46
jackinnj's Avatar
R12 is in parallel with the sense network (2.43K +1.82K), so the pole is closer to 5kHz. R1,C1 is a zero @655kHz.
Here is the response of the Rail Driver without compensation:
and with compensaton:
Old 14th April 2011, 04:55 PM   #47
Thanks belleson, your last posts exactly explained what I was curious about.
Looks like great performance for only 9 parts.
Old 14th April 2011, 06:46 PM   #48
jackinnj's Avatar
Everything looks better with the Jung regulator driver -- it's pumping out at 18V. The Belleson, indeed looks much, much better with this setup. I think I was over-driving all of these regulators with way too much ripple.
This is, essentially the setup I'm now using to measure LR.
Old 14th April 2011, 07:53 PM   #49
The LM317 was tested with Cin=0.1uF, Cref=10uF, Cout=1uF, R1=270 Ohms, R2=2K Ohms, Vin=30V, Vout=10.8V. An 8 Ohm load was switched from Vout to ground using a D880-Y power NPN. The SPJ Superpower uses a standard D44H11 or D45H11 output transistor.
If you are planning to use regulators in parallel, I suggest the LT3080 or something similar, not LM317.
Brian,
The LM317 setup seems reasonable and I find your suggestion to use an LT3080 refreshingly honest (although it still is an expensive IC).
Thank you.
Greetz,
MatchASM
Old 15th April 2011, 03:54 AM   #50
{images clipped}
This is fine, but it's not a bandwidth problem it's a slew rate problem. If the tested regulator has any capacitor C5 on the input, as some require for stability, this affects the negative slewing of the rail driver output. The maximum negative slew rate is set by
dV/dt = 2pi(f)Vmax where Vmax=Vpk of the sine wave (not pk-pk)
Current I5 flows into and out of C5 as the rail output oscillates:
I5 = C5(dV/dt), and the dV/dt is set by I5 = Vout/R12
Combine these and you get
Vout/R12 = 2pi(f)(Vmax)(C5)
You can plot C5 vs. f to see the maximum clean sine frequency per uF, or choose a value for C5 and plot the maximum sine amplitude vs. frequency.
The two oscillogram simulations are using C5=1uF, the first is at 10Khz and you can see the linear slew of the green Vout as it hits the limit (red is the modulation signal V2). The second one is 40KHz and the output barely makes it back to mid-scale before the next cycle comes along. This is what I was referring to in post #45 when I said the test signal to the DUT is no longer a valid amplitude, nullifying the resulting measurements w.r.t. 0dB.
Note that V2 was inverted and scaled by +18Vdc to be visible and compared to rail driver Vout.
This is much less of a problem if the tested regulator has no input capacitor, but you have to be careful.
High Voltage Huge Storage CAPS for that Ultimate Valve Amp col Parts 0 11th December 2009 03:37 AM
Ultimate Amp with High offset voltage glen65 Car Audio 4 16th October 2007 12:19 AM
Ultimate shunt regulator Rtop84 Power Supplies 8 5th May 2006 08:16 PM
Voltage regulator annex666 Solid State 1 27th August 2003 03:50 PM
Voltage regulator help! kasra Solid State 7 23rd November 2002 03:07 PM
Copyright ©1999-2017 diyAudio
