The Belleson Superpower, the ultimate voltage regulator ... ?
Old 28th March 2011, 01:57 PM   #21
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally Posted by BMW850 View Post
Hi jackinnj,
How do you think about to compare also the Sallas regulator, you find this tread here:
The simplistic Salas low voltage shunt regulator
Rudy
It's an enormous thread with around 4,000 posts. I have printed out a couple of the schematics, but have to figger out which one is the definitive Salas!
Old 28th March 2011, 01:58 PM   #22
hesener is offline hesener  Germany
have the same problem.... is there a "summary" somewhere?
Old 28th March 2011, 04:13 PM   #23
martin clark is offline martin clark  Europe
Originally Posted by MatchASM View Post
so I guess at some point even the most critical audiophile is happy with the remaining noise floor?
Funnily enough I think if the regs output noise is not correlated with the load current, then it doesnt matter very much in and of itself.
To me that, means achieving that means very low output Z over a wide bandwidth is highly desirable, but after filtering out incoming crud and being 'reasonably' quiet over a nice wide bandwidth - there's no need to go mad on noise. Focus on regulation.
Old 29th March 2011, 01:40 PM   #24
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
Originally Posted by jackinnj View Post
OK -- here's the PSRR test of several regulators mentioned -- the Belleson is consistent, but hardly outstanding.
I used a Jensen 600:600 ohm transformer -- very flat from a few Hz to 200kHz -- it's the model AP uses in their PSRR test. The injected voltage was 1V RMS.
What I find most interesting about those PSRR plots is that the Belleson's is, as you observed, consistent. None of the usual PSRR degradation with increasing frequency, well, at least not within the test bandwidth.
Old 29th March 2011, 04:01 PM   #25
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Hi jackinnj,
This is the final definitive schematic of the Salas regulator.
I hope this is the right one, I ask in the other thread the schematic and I get this one.
Rudy
Itís not what you know, but who you know ďand where they areĒ
Old 29th March 2011, 04:39 PM   #26
BMW850's Avatar
Maybe this one is also interesting Peter Daniel use this one in the Shigaclone and his DAC.
Finally, an affordable CD Transport: the Shigaclone story
Rudy
Old 29th March 2011, 09:58 PM   #27
stormsonic is offline stormsonic  Slovenia
stormsonic's Avatar
Good topology, bad implementation.
Old 1st April 2011, 04:31 PM   #28
jackinnj's Avatar
Hi jackinnj,
Rudy
Some of the earlier ones I simmed -- I get very good numbers.
Old 6th April 2011, 11:26 AM   #29
BMW850's Avatar
Hello jackinnj,
How are the measurements at the moment now.
Have you done comparisons with the other regulators, which regulator have the best papers ?
Rudy
Old 6th April 2011, 12:17 PM   #30
jackinnj's Avatar
Hello jackinnj,
Rudy
Nothing to report.
The Belleson Superpower, the ultimate voltage regulator ... ?Hide this!Advertise here!
High Voltage Huge Storage CAPS for that Ultimate Valve Amp col Parts 0 11th December 2009 02:37 AM
Ultimate Amp with High offset voltage glen65 Car Audio 4 15th October 2007 11:19 PM
Ultimate shunt regulator Rtop84 Power Supplies 8 5th May 2006 07:16 PM
Voltage regulator annex666 Solid State 1 27th August 2003 02:50 PM
Voltage regulator help! kasra Solid State 7 23rd November 2002 02:07 PM
