The Belleson Superpower, the ultimate voltage regulator ... ?
Old 27th March 2011, 04:23 AM   #11
iko is offline iko  Canada
iko's Avatar
Right, size is what it is. Don't forget heat and power consumption; those are also excessive with a shunt reg. But hey, there's not replacement for displacement right? It's not for everyone, that's for sure. Some people are fine with Priuses That's the beauty of diy, everyone chooses whatever scratches their obsessive audio itch.
Old 27th March 2011, 12:44 PM   #12
stormsonic is offline stormsonic  Slovenia
stormsonic's Avatar
@iko
you're flaterring me, thank you. I'm not young any more, but still not THAT old to be called Mr.
@MatchASM
you can get order of magnitude (10x) lower broadband noise (20Hz-20kHz) without big sweating. If you want to stick with LM317 and improve it, then invest 0,5€ for transistor, few resistors and cap and go to this excellent thread.
Old 27th March 2011, 07:43 PM   #13
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally Posted by jackinnj View Post
Tomorrow I'll run the LR and Z test on the Belleson.
OK -- here's the PSRR test of several regulators mentioned -- the Belleson is consistent, but hardly outstanding.
I used a Jensen 600:600 ohm transformer -- very flat from a few Hz to 200kHz -- it's the model AP uses in their PSRR test. The injected voltage was 1V RMS.
Old 27th March 2011, 10:12 PM   #14
MatchASM is offline MatchASM  Europe
Thanks for the link; by coincidence I stumbled on that same schematic earlier today after some Googling (TM) [will always sound better than "Binging"...].
The 10x improvement refers to this circuit, no? It seems to me that, in general, the output voltage noise can be made arbitrarily low by putting zillions of voltage references in parallel. So really, the challenge lies in output voltage noise versus consumed bias current (which is what the Dieckmann circuit seems to do quite well).
Now that I think about it, 4kTR and 4kT/gm noise depend on temperature, so at some point it must make more sense to add a refrigerator rather than another million voltage references. I have not seen anybody do this, so I guess at some point even the most critical audiophile is happy with the remaining noise floor?
Greetz,
MatchASM
Old 27th March 2011, 10:19 PM   #15
johnferrier is offline johnferrier  United States
johnferrier's Avatar
Interesting. Thanks for taking the time to measure and post !
Michael Gazzaniga - "The arts are not frosting but baking soda."
Old 27th March 2011, 10:21 PM   #16
Excellent work; thank you very much.
It seems from these plots that the teddyreg is the best performing candidate. I actually expected it to be much better than -100dB. Is there some X-talk between input and output (i.e., does better shielding help...)? I would be very interested in the addition of an LM317 preregulator configuration to the list of traces; when properly soldered, it should also be able to do -100dB.
Greetz,
MatchASM
Old 28th March 2011, 12:41 AM   #17
stormsonic's Avatar
No, it refers to Belleson.
No, you just need to filter out the noise of your single voltage reference. High frequency noise is easy to filter, much harder to filter out low frequency. I won't go into details, there are very detailed, great articles and examples on Walt Jung's website. A MUST read.
Old 28th March 2011, 01:16 AM   #18
jackinnj's Avatar
We have to fold this discussion into some SuperReg thread -- I got in some Jung-Didden boards a few weeks back but had run out of D44H11 transistors to solder them up -- would like to compare them to all the above. Jung used a somewhat different methodology for the Line Rejection test, so an apples to apples comparison requires that they all go on the same board of nails.
Old 28th March 2011, 12:33 PM   #19
jackinnj's Avatar
Or a Peltier device.
Liquid helium will help.
Old 28th March 2011, 01:28 PM   #20
BMW850 is offline BMW850  Netherlands
BMW850's Avatar
Hi jackinnj,
How do you think about to compare also the Sallas regulator, you find this tread here:
The simplistic Salas low voltage shunt regulator
Rudy
It’s not what you know, but who you know “and where they are”
The Belleson Superpower, the ultimate voltage regulator ... ?Hide this!Advertise here!
High Voltage Huge Storage CAPS for that Ultimate Valve Amp col Parts 0 11th December 2009 02:37 AM
Ultimate Amp with High offset voltage glen65 Car Audio 4 15th October 2007 11:19 PM
Ultimate shunt regulator Rtop84 Power Supplies 8 5th May 2006 07:16 PM
Voltage regulator annex666 Solid State 1 27th August 2003 02:50 PM
Voltage regulator help! kasra Solid State 7 23rd November 2002 02:07 PM
