Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th March 2011, 02:49 AM   #1
Default Please check my first HV regulator
Hello,
I want to build a regulated B+ PS for an amplifier I have. It now has a passive RC filtered supply. However, this will be my first one and I'm not sure I got it right.
Thanks!
Old 25th March 2011, 03:48 AM   #2
jfitz57 is offline jfitz57  United States
Originally Posted by diego6339 View Post
Hello,
Thanks!
Being more of a SMPS person, 3 X 470uf of input C seems excessive for a little over 20 watts out.
But more important, I hope you just omitted a line isolation transformer from the schematic so that it would fit on the screen.
Old 25th March 2011, 06:24 PM   #3
That´s right, I already have a toroidal transformer with a 120 volt 1 a secondary. I´m going to add it to the schematic to make it clearer.
With regard to the input capacitance, I also suspected it was too much but this is for a OTL 6080 based headphone amp and I want it to be very quiet. Also, there are only 9v across the IRF840 so the ripple has to be low. According to PSUII, if I only use one 470uf capacitor the ripple would be a little over 2v but I am not sure if that would be quiet enough.
Thanks a lot for your input,
Diego
Old 26th March 2011, 01:07 AM   #4
If you had said it was for an OTL headphone amp at the beginning I would not have questioned even
4 X 470uf. I have not looked at the rest of the schematic yet but I will let you know if I find something that does not look right. Cool idea!
Jim
Old 26th March 2011, 09:42 PM   #5
Here's more info on the amp.
HV Regulator board rsumperl Tubes / Valves 0 27th September 2010 01:08 AM
HV Regulator rsumperl Tubes / Valves 4 18th September 2010 07:20 AM
HV Regulator habsrock93 Tubes / Valves 3 21st October 2008 07:15 AM
PCB for HV Regulator jackinnj Power Supplies 13 5th February 2006 03:20 PM
Page generated in 0.09297 seconds (76.71% PHP - 23.29% MySQL) with 11 queries
