Idea was to use a voltage doubler for the higher Voltage supply for the front end...Use some CLC filtering and the chop it down with a Salas Like shunt...to get app +-90 V...
Mirroring the Salas Shunt does not give the desired results at the voltages end up a few V apart....95 V vs 102 V.. Is this due to differences in the shunting mosfets...or am I missing something else..?? |
#2 |
It is not close to a Salas style shunt regulator.
It has omitted the CCS stage. Scrap it and adopt a real Salas Shunt. Use 150V or 200V Vfets for the 4 active power devices. Going back to your schematic. The output voltage is Vbe Q3 plus V across R9 (82k). The Vbe has only a tiny change for operational conditions. Your "error" is due to the simulator selecting a different current passing through the two 82k resistors. It's another example of asking the simulator the wrong question and as a result getting a wrong answer. You must understand the operation and be able to check the results before you adopt software to save on the arithmetic. If you cannot check the results then you should not be using the software.
regards Andrew T. |
#3 |
How nice....
Thanks...You realize i am asking questions to learn, not to be ridiculed..??? |
#4 |
You are closing your mind to learning.
There are a number of lessons in my reply. "How nice" implies you will ignore at least some of them. I will repeat the most important lesson. You must be able to understand what the software is doing and be able to check the results before ever relying on any questions/answers of that software. Learn the operation first. Be able to do it with pencil and paper. Then you are ready to take shortcuts with the assistance of software.
regards Andrew T. |
#5 | |
#6 | |
diyAudio Chief Moderator
#7 |
Drawing excessive current from a doubler supply (via a shunt reg) is probably not the ideal. Using a linear regulator makes more sense.
#8 |
Shunts are not power efficient, no question about it. For what application is that? What will be the demanded average & peak current?
#9 |
Salas
Thanks for the suggestions.... ![]() Its for powering the fronted of my amplifier..I use app 85-90 V rails, consumption is app 40 mA...making for a total of 80-90 mA for both channels.... |
#10 |
If you will go such super regs (i.e. CCSed shunts) in the end, you got to run them +23mA on top of your max consumption per rail. Check what is drawn on max swing of your VAS. ICCS=(VF3xLEDS-VGSQ1)/R1. Those attached are the simulated loop gain and Zo characteristics. Vin-Vout 20V will be fine, safe from mains and toroid's sags. Keep short output cables, and have good luck.
| seperate regulated front end for f4 | slr 5000 | Pass Labs | 1 | 29th September 2010 11:29 PM |
| Choke loaded PSU versus VR tube regulated PSU? | G | Tubes / Valves | 37 | 20th March 2008 10:45 PM |
| Noisily front end | mantistube | Analogue Source | 10 | 16th January 2006 01:57 AM |
| Aleph's front end separate power supply | Peter Daniel | Pass Labs | 24 | 10th April 2002 09:48 PM |
| a75 front end supply | SteveG | Pass Labs | 2 | 23rd January 2002 10:02 PM |
| Page generated in 0.11442 seconds (80.33% PHP - 19.67% MySQL) with 11 queries |
