I need to create a third rail at about -1V from an existing dual power supply (+/- 15V for instance). The -1V rail needs to supply up to 50mA but the current demand is not constant.
How do I do this? Can I just use a PNP transistor with the base supplied with the voltage that I would like to achieve, e.g. using a voltage divider between ground and the existing regulated -15V rail as the reference? Also, I should connect the emitter to the -15V rail and the collector to ground? This seems like a pretty basic valve, but I can't seem to get it to sim correctly. If this is not the way, then how???? HELP! -Charlie |
#2 |
A diode string is easy enough, though not exactly elegant, it'll do the trick.
#3 |
#4 |
A slightly shifted voltage regulator?
#5 |
Try this.
There is no feedback in this circuit, but I am sure it will deliver a resonably accurate, temperature stable -1V. Simply adjust R1 for the correct output voltage. note, the 220 Ohm resostor in the output pass transistor collector is simply a dissipation limiter. |
#6 |
#7 |
I noticed this last night after I posted the thread. For some reason I thought the minimum was around -3.5V , but then I read the datasheet.
Since it would be pretty simple to implement, I might just go with an LM337 and live with the -1.2V output. That will probably work just fine for my application. I am still interested in implementing something like a voltage follower using a transistor, but I have only seen them drawn with a positive source voltage. I can't say that I really know much about transistor circuit design, so I am a bit at a loss. It seems like there should be something using a single transistor that is simpler than the LM337, but I can't come up with it. -Charlie |
#8 |
which direction is the current going, series Reg chips don't work both directions
a Vbe multiplier shunt is a low parts count option too |
#9 |
A standard-red LED and a ballast transistor will give you a crudely compensated ~1V output:
#10 | |
-Charlie |
| Wanted: Op-amp with single supply, 32V or more, and rail-rail capability | akis | Power Supplies | 3 | 13th November 2010 01:53 PM |
| comining rail to rail and rail to ground decoupling? | jazz | Power Supplies | 2 | 30th March 2010 01:13 AM |
| Suggested AWG for 6.3V tube heaters rail and 250V B+ rail | eranrund | Parts | 0 | 3rd November 2008 07:30 PM |
| Filter Cap Directly from Rail to Rail, excluding Center Tap | Workhorse | Power Supplies | 8 | 29th August 2007 12:33 PM |
| Page generated in 0.08997 seconds (86.40% PHP - 13.60% MySQL) with 11 queries |
