Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th March 2011, 06:19 PM   #1
Default Low Noise 5V Reg
What do you think about the following circuit:
http://img859.imageshack.us/i/5vreg.jpg/
Old 20th March 2011, 06:56 PM   #2
Well, it looks a lot like the feedforward 'clean-up' shunt regulator design of Wenzel Associates. Except that it has an second (incorrect) phase inversion due to having cascaded two grounded-emitter stages.
Ken
Old 21st March 2011, 11:21 AM   #3
Why are R1 and R2 both in there?
Is something missing?
Why has you used a remote server to store the pic?
We will lose it when image shack decides to break the link.
Attach a compressed, appropriate resolution pic to your post.
regards Andrew T.
Old 21st March 2011, 09:38 PM   #4
ywara is offline ywara  United States
I can't say I'm certain what you're trying to achieve here. You'll get a maximum 2dB rejection across the audio spectrum with full 1A load, and effectively zero rejection at reasonable loads.
Old 22nd March 2011, 01:32 AM   #5
I found the original source of this topology (well, ONE original source) here: Finesse Voltage Regulator Noise! (Fig. 2)
Basically, the OP's circuit needs a PNP as the high-current shunt transistor.
The suggested PNP darlington pair wasn't too much fun to bias with only 0-5V to play with, so I gave the 2n4403 a shot. With proper biasing you can get around 18dB rejection at 120Hz. It also seems incredibly sensitive to the surrounding components, especially R1/R2. It doesn't seem terribly sensitive to differing loads.
It's a pretty useful topology, but with temperature drift and component tolerances potentially wreaking havoc on its ability to reject high frequencies, it might just be a waste of power.
+5V high current low noise regulator? Kuro Power Supplies 54 27th March 2011 01:00 AM
Could someone help me with a reg. with 0.1-0.5V out tobias_svensk Power Supplies 34 8th September 2008 10:34 AM
High(er)-voltage, low noise v-reg? Khron Power Supplies 8 1st June 2007 11:54 AM
anyone tried this for low noise 5v? mlloyd1 Digital Source 1 25th May 2006 12:06 PM
Very Low Noise 5V Jung Reg fmak Digital Source 2 15th July 2004 05:20 PM
Page generated in 2.69097 seconds (-89.09% PHP - 189.09% MySQL) with 11 queries
