Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th March 2011, 04:47 AM   #1
Default finger sized ferrite rods
In the Lampizator design of a mains "filtering" unit called SILK:
AC filterr DIY ESA SILK
the designer talks about "finger sized ferrite rods" and "finger type ferrite rods"
Can anybody tell me what they are and/or what the difference is between the two?
Old 20th March 2011, 05:43 AM   #2
no reply? every reader as puzzled as I am as to the difference of the 2?
Old 20th March 2011, 08:29 AM   #3
I think he's referring to the kind of rods that are used for antenna coils (on the back of some receivers/radios) ?
Check your 'junk box'...
Old 20th June 2011, 04:33 AM   #4
hello audofanaat.. i'm also thinking of doing this filter by lukaz and while shopping for the materials, i found this.
SCHAFFNER|FN9244E-10-06|IEC INLET, FN9244E, EARTH CHOKE | element14 Singapore
what do you think? have you got all your materials already?
Old 21st June 2011, 12:23 PM   #5
stormsonic's Avatar
Check at Farnell.
Part # 1635813 is 6 mm diameter and 30.9 mm lenght
Part # 1635817 is 12 mm diameter and 30.9 mm lenght
Both are already made inductors, but they can be easily unvinded
Old 21st June 2011, 01:11 PM   #6
There are all different types of ferrites and winding wire around an unknown type seems just plain foolish. The usual large rods are often used for AM antennas and may be type 43, but there's no guarantee. I'd start with Amidon as a source of both rods and info.
I used to be an audiophool like you but then I took an arrow to the knee.
Old 22nd June 2011, 06:36 AM   #7
Conrad, I was actually planning to build this line filter based on Lukasz schematic. (see the attached link below). Hence, why I was looking for the ferrite rod. Any suggestions on a suitable type for this? Appreciate your help.
Cheers!
Burnt my finger - OPA4134 Ridin '24'z Chip Amps 8 11th April 2008 11:11 PM
Thin Metal Rods for Grills sdclc126 Multi-Way 12 11th January 2008 03:53 AM
Finger joints vs. screw and glue PRNDL Tubes / Valves 35 21st November 2006 12:24 AM
Coil rods knubie Planars & Exotics 2 14th March 2006 06:32 PM
Finger Cellular Phone Netlist Digital Source 8 14th November 2003 09:01 PM
Page generated in 0.07946 seconds (84.43% PHP - 15.57% MySQL) with 10 queries
