Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th March 2011, 03:42 AM   #1
Mamak is offline Mamak  Malaysia
Default maximum voltage for capacitor
if i have 10000uf/100V capacitor,what maximum voltage for this cap work very well?
Old 17th March 2011, 04:52 AM   #2
100v! ????
Old 17th March 2011, 06:47 AM   #3
just another
wintermute's Avatar
Hi Mamak, the two things you need to take into consideration are (assuming this is for use as a smoothing cap in a powersupply) the transformer regulation, and the mains voltage fluctuations. in a worst case scenario you need to add 20% for mains Plus the transformer regulation.
Say you have a transformer with regulation of 6%. When it is running with no load the voltage output will be 6% higher than the nominal rated voltage. If the mains is also at its maximum variation of +20% you need to increase that by a further 6% or around 27% in total.
Based on this a nominal voltage of around 78V (at full load with standard mains voltage) should be safe with 100V caps.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 17th March 2011, 07:47 AM   #4
just another
wintermute's Avatar
sorry I think that figure of 20% for mains variation is wrong (too high when I actually did the calculation for 240V)... I'll have to check
a quick google search resulted in Australian standards being 230V +10% -6%
so substituting 10% instead of 20% above we would get approx 85V for the safe post rectification no load at nominal mains voltage. Obviously the power specs in your area should be used as a guide
Tony.
Some of my photos
Old 18th March 2011, 02:14 AM   #5
jfitz57 is offline jfitz57  United States
The voltage on the capacitor is the "working voltage". If your transformer puts out 70 volts or less then it will work well.
Old 18th March 2011, 09:54 PM   #6
Shelby is online now Shelby  Austria
Default transformer
take care. transformer should not deliver more than 60Vac. Vdc ~ 1,41 times higher!!!
Maximum Voltage for Mosfet Output Stage? Xoc1 Solid State 12 6th September 2009 02:26 PM
Capacitors and maximum voltage ratings hilbert_mostert Tubes / Valves 13 9th May 2009 09:05 AM
2A3 maximum plate voltage alexg Tubes / Valves 11 9th March 2008 05:39 AM
Maximum voltage for LM4780 G.L. Tirebiter Chip Amps 5 6th March 2005 09:06 AM
Page generated in 0.08264 seconds (76.24% PHP - 23.76% MySQL) with 10 queries
