Critique my UCD400 linear PS
Old 14th March 2011, 09:32 PM   #1
badman is offline badman  United States
badman's Avatar
Default Critique my UCD400 linear PS
Heya:
Any feedback on this schema? Specifically, the use of the resistors. I'm figuring as long as I'm not running high power sinewaves, there should be minimal voltage drop. I'm not going to be running this high power often (if at all) and if I find it to be an issue I can always bypass the R.
If it matters to y'all, diodes are HexFreds and heavily heatsinked, caps are quality cornell dubliers, with poly bypasses, resistors are big wirewound dealies (95W 8 ohm, 2 in parallel). Oh yeah, little 100nF ceramic bypasses on the diodes are in there too.
I'm thinking I'm going to drop the change on a hypex soft-start, unless someone else has an easy inexpensive solution (not series thermistors). Also, I'll fuse the rails.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 16th March 2011, 08:07 AM   #2
luka is offline luka  Slovenia
luka's Avatar
Yes this will work, since light music (even if loud) will not draw much power...
why do you need those resistors in place?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 16th March 2011, 11:34 AM   #3
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Hi Badman, You *might* get more ripple reduction with a CRCRC with 2 ohms for each R rather than CRCC with 4 ohms.. I'd have to sim it to see... What sort of current are you looking at? if you are drawing 1amp you are going to get 4V drop....
Also wondering what the 50 ohm resistors in series with the 1uF caps on the output are for??
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 16th March 2011, 12:09 PM   #4
just another
wintermute's Avatar
OK Just did a sim, and as I suspected ripple is quite a bit less with CRCRC instead of bigger R and CRCC
blue is with CRCC 4 ohms, green CRCRC with 2 ohms for each resistor.
Load was around 900mA. (Sorry don't know what your likely actual load is).
Tony.
Some of my photos
Old 16th March 2011, 12:37 PM   #5
luka's Avatar
music...
I FEEL SLOVENIA
Old 16th March 2011, 04:09 PM   #6
badman's Avatar
The resistors are there for ripple reduction- no cap bank can prevent all ripple voltage from getting to the load without some resistor/inductor/regulator to help it along.
Tony.
Yes, I certainly would. The only challenge is that this is a high-power amp and thus resistors are big and expensive. I'm planning to use what I have on hand: 8 ohm big resistors (like 9" long) in parallel for the job. Dual 2 ohms... I'd probably run out of resistors and fill up the chassis something fierce (8 resistors per channel, as the supplies will be dual mono).
As far as current, I want it to support up to about 4A, giving me most of the 400W potential into 4 (continuous, naturally short peaks are reliant on the cap bank).
The resistors on the 1uF are just for damping, prevent any resonance in the supply.
Old 16th March 2011, 04:12 PM   #7
luka's Avatar
but then again, why not go with industors? resistors are only good coz they are cheap, not coz they are the best... even better would be regulator
I FEEL SLOVENIA
Old 16th March 2011, 05:14 PM   #8
BZed is offline BZed  United States
What class amp is this?
If its a class "A" amp then there isn't going to be much load induced voltage change of the supply output. The current will idle at about 2 amps and swing from 0 to 4 amps under dynamic conditions. The amp should be able to live with that.
If its a class "B" or "AB" then this type of supply will have the voltage drop across those resistors causing a lot of change in output voltage under dynamic conditions. Up to 16 volts of load induced voltage change in output voltage for each rail. Not a good idea. You could have stability issues, big time.
I would go for a series regulator. A much better option.
BZ
Old 16th March 2011, 05:43 PM   #9
luka's Avatar
its class D
I FEEL SLOVENIA
Old 16th March 2011, 05:54 PM   #10
badman's Avatar
BZ
It is indeed class D, and thus the supply will have minimal long term drag, with real world music. I'm thinking the time constant for voltage drift would be long enough that instability would not be an issue, but I'm certainly open to options- that's why I'm posting here!
Got a series regulator in mind for +/- 60V DC and 4A? I'm poking around a little bit, but to be honest my regulator experience is exclusively in 3 leg LM317 etc., simple cheap little low-power circuits.
Critique my UCD400 linear PSHide this!Advertise here!
SMPS vs LINEAR PS: Let's build up a serious technical review-list Centvrion Power Supplies 18 7th March 2011 04:09 AM
PS Audio Linear Control Center and Phono III tomman888 Solid State 2 16th May 2009 09:21 PM
Linear PS help ashley_kitty Power Supplies 2 16th May 2007 12:00 AM
Need help with linear PS tonyptony Power Supplies 33 14th April 2006 09:37 AM
Parts selection for linear PS tonyptony Parts 3 29th March 2006 02:15 AM
Copyright ©1999-2017 diyAudio
