Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th March 2011, 02:07 PM   #1
Default Upper limit of R in CRC any issue besides dissipation ?
HI Everybody,
I'am just playing around with PSUD2 and was wondering of the was an upper limit on the resistance for the R in a CRC or CRCRC filter.
I am aware of the power dissipation and the voltage drop, but is there something I might have overlooked ?
Funny thing is that when getting above a certain resistance level the ripple voltage starts to increase again, going higher than something like 5R in a CRC with a total of 20000 uF in my particular case.
Thanks in advance,
Max
Old 14th March 2011, 04:43 PM   #2
With all the acronyms and lack of references, I find it impossible to understand your question, much less give an answer. Post a diagram and explain in words, not symbols.
Old 14th March 2011, 04:57 PM   #3
I agree with your opinion. I wonder if he's describing a pi filter with resistors instead of inductors? If that is the case the only other thing is there is a maximum voltage on resistors regardless of dissipation as shown in this Vishay datasheet. See note 1.
http://www.vishay.com/docs/31012/31012.pdf
Old 14th March 2011, 07:00 PM   #4
DF96 is online now DF96  England
The ripple voltage on the first (reservoir) capacitor will rise with the resistance, but the output ripple (second cap) should reduce. In real life you need to get the grounding right too, but PSUD2 will not worry about that.
Old 15th March 2011, 01:18 PM   #5
This resistance increases the PSU's total internal resistance and limits the peak flow of current.
In audio applications you can hear the bass getting softer and softer...
CRC Filter ? kacernator Tubes / Valves 2 31st July 2009 10:15 AM
ZV9 upper limits??? sandyhooker Pass Labs 4 27th December 2008 03:24 AM
PHL 1120 upper frequency limit? distortion performance? thadman Multi-Way 0 6th May 2007 05:41 PM
Crc Clc ?????? chipco3434 Pass Labs 3 11th July 2005 06:52 PM
Choosing R in CRC Michael Rothacher Pass Labs 5 25th March 2003 08:06 PM
Page generated in 0.09027 seconds (73.72% PHP - 26.28% MySQL) with 10 queries
