For power amplifiers it is quite common practice to use a separate high current supply for the output current buffer and a separate high voltage supply for the input and VAS stages. Some uses a separate transformer for the latter. An alternative, however, is to use a voltage doubler.
The attachment shows my planned full wave voltage doubler. But I have not seen it used. What do you think? Am I missing a point somehow, since the solution is not used, or is it? |
#2 |
All the extra capactiors, no need for that much extra voltage, and the regulation/isolation of the high voltage supplies is still limited by the output loading of the high current supply.
#3 |
I would think it is a good practice to have a regulated voltage for the input and VAS stage. When using MOSFET's, then a 10 V (min) extra voltage is needed above the output buffer supply. I would think a couple of extra capacitors would be a reasonable price?
#4 |
It could work out OK for the voltages posted and with regulators, but you can see that by the time you get to 50 volt power rails, 100 volt driver supply is just pretty much out of hand. So for higher power amps you probably wont see it.
#5 |
I agree on that, but I thought most designers used regulated supply for the voltage stages.
#6 |
I used one, when I built an amp with a fellow Norwegian guy.
I works fine, but the one I built was a lot simpler: a hint: use +-24V as a reference for boost bridges, save some capacitors at the expense of 50Hz ripple. |
#7 |
Anyway, real men design circuits (including amplifiers) to operate on single, non regulated rails.
Multiple supplies are an expedient for the weak and feeble-minded. |
#8 |
I have my own suspicions about guys who like to emphasise what 'real men' do or do not.
| Split Voltage Switching Power Supply for Power Amp | vectorplane | Swap Meet | 2 | 23rd April 2011 11:48 PM |
| Supply voltage doubler question | ashok | Power Supplies | 33 | 16th July 2010 07:49 PM |
| Building an amplifier power supply using a voltage doubler and LM317? | hornloaded | Solid State | 22 | 31st March 2010 04:50 PM |
| worth building a PS or Voltage Doubler for this amp? | DJNUBZ | Car Audio | 1 | 25th February 2008 06:29 PM |
| Voltage Doubler Supply for Power Amp? | NiccoloDeiConti | Solid State | 14 | 16th June 2003 08:01 AM |
| Page generated in 0.09768 seconds (72.19% PHP - 27.81% MySQL) with 11 queries |
