Hi.
I have Pro-Ject Phono Box SE II and I want to supply through batteries. I have two batteries from the UPS each at 12v . I need the preamp voltage V 12-0-12 or 16-0-16v. If I connect them I get a 24-0-24 V. Instructions are written in German but it has a picture of how to connect the battery. If anyone has advice on how to use my battery and get a 12-0-12v I would be grateful. http://www.project-audio.com/inhalt/...phonoboxse.pdf |
#2 |
Batteries from a UPS to power a phono preamp sounds like super overkill!
It would probable work fine on a pair of 9 volt "transistor radio" batteries. |
#3 |
Personally, I hate 9V PP3 batteries for anything but multimeters.
Whatever batteries you use, you'll want to connect one battery's + terminal to the other battery's - terminal. That point will be the 0. The remaining + and - on the two batteries will be +12Vcc and -12Vee respectively. If you connect two 12V batteries and get 24-0-24 V... PATENT IT! Last edited by sofaspud; 13th March 2011 at 06:54 AM. |
#4 | |
#5 | |
And I am sure that they are 12v battery. |
#6 |
Sorry I am not familiar with the Project phono SE I had the small Project and that was suplied with a out of the wall 16 suply.(think it was £36)
Is this correct? Now I am running a MC phono preamp out of 2 LAC 12 v each in series =24 rated at 2.3 A/H It has been running for last 3 years. I am using a LM 317 and transistor to charge up the cells. and voltagge comparators to monitor charge. If you new to charging batteries gogle up The Batery university. There is a bit of details to look in to when going this way as the cells never charge discharge at the same rate so it is difficoult that you will get say for example 12.5 +V and 12.5 -V I am using a buffer and voltagge devider to kepp the ground exactley in the midle. And vhen not in use the cells are in parralel so to equalise the voltagge. I have noticed quite a it of difference between normal and LAC suply Sound stage is much firmer and more defined with the LAC and a bit of fuziness gone from Hi Band.(this with My phono stage) Worth doing if this is what you look for but as I said I am not familiar with your project stage. Let me know if you need help with charger and such I will dig out the old drawings |
#7 |
I'm not an electrician so that the first clear up this.
Is this corect? |
#8 |
#9 |
Bksabath please can you put everything on the forum that you have, thet can help me!!
#10 |
Like this...
| Pearl phono with 24V battery supply | koli | Pass Labs | 1 | 9th August 2007 05:03 AM |
| Grid battery bias on phono.... | fred76 | Tubes / Valves | 16 | 10th September 2005 09:24 AM |
| Battery powered phono. | GeirW | Tubes / Valves | 6 | 4th December 2004 07:40 PM |
| Battery operated phono amp | diyman | Analogue Source | 1 | 9th September 2002 01:52 PM |
| pearl Phono stage battery option | schatz | Pass Labs | 1 | 12th February 2002 03:04 AM |
| Page generated in 0.10530 seconds (80.26% PHP - 19.74% MySQL) with 11 queries |
