Go Back   Home > Forums > Amplifiers > Power Supplies
Old 11th March 2011, 05:20 AM   #1
prakash is offline prakash  India
Default driving full bridge using ir2110
hi i have looked into the datasheets , ir application notes and still have problems hooking up ir2110 .
based on what i have read i have drawn the circuit . is ther anything to add.
has the pin Vb to b connected to anywhere , and Vcc to the ground . do i need a isolator like opto coupler to isolate the pic inputs and inputs of ir2110 . is Vdd and Vss the logic level inputs .
hope i am clear about my doubts .....anticipating your reply Click the image to open in full size.
Old 11th March 2011, 06:14 AM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
You need to supply 12v to Vcc... this has to be 12v above gnd of a fet, if grounds are not the same as on primary side
You do not need to insulate inputs, unless you say have pic on secondary side of supply, IR's are on primary
Vdd campared to Vss can be 5v only, 3v min from datasheet
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
driving full bridge using ir2110 prakash Construction Tips 0 10th March 2011 11:30 PM
how ir2110 drives the high side mosfet in h bridge gowri Class D 2 10th April 2008 06:30 AM
ir2110 full bridge high power umut1001 Class D 7 21st May 2007 09:44 AM
The difference of Push-pull,Half-bridge,Full-bridge digi01 Chip Amps 0 8th September 2006 02:10 AM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 07:23 PM
Page generated in 0.06768 seconds (67.58% PHP - 32.42% MySQL) with 10 queries
